orangeman Posted February 1, 2019 Report Share Posted February 1, 2019 I have been using a 3 M fine sanding wheel in a Delta variable speed lathe to sand all my puzzle pieces. Lathe is set to 1750 rpm as it won't burn cherry at that rpm. Then I discovered I had a slow speed bench grinder which is 1725 rpm. Purchased from Woodcraft several years ago for under $100. So I ordered a 5/8" - 11 drill chuck and it fits perfectly on the grinder!!!!!! I tested it today with great results. I will now use the slow speed grinder for sanding puzzle pieces!!!!! And will put the Delta midi lathe up for sale. Was considering the Foredom variable speed sanding lathe but no need now. bb WayneMahler, Scrolling Steve, OCtoolguy and 2 others 5 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted February 1, 2019 Report Share Posted February 1, 2019 I use my little Delta lathe for my Mac Mops.... works great. My lathe tools are getting rusty! SCROLLSAW703 and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted February 1, 2019 Report Share Posted February 1, 2019 3 hours ago, Scrappile said: I use my little Delta lathe for my Mac Mops.... works great. My lathe tools are getting rusty! I do the same. OCtoolguy and SCROLLSAW703 2 Quote Link to comment Share on other sites More sharing options...
Rolf Posted February 1, 2019 Report Share Posted February 1, 2019 (edited) Great idea! This is my traveling mop that I take to our wood working shows. I should have added that the motor is mounted on a board and at the other end is a wall switch. The board makes it easy to clam to a table. Edited February 2, 2019 by Rolf SCROLLSAW703 and NC Scroller 2 Quote Link to comment Share on other sites More sharing options...
Sycamore67 Posted February 1, 2019 Report Share Posted February 1, 2019 I sand either on my Shopsmith or my drill press On the Shopsmith, I use a pneumatic drum sander, Mac Mop, regular mop sander and buffing wheels. I like to be able to turn the speed way down at times. My drill press gives me 50 -5000 rpm and use mainly with sanding or Mac Mops and small drum sanders. SCROLLSAW703 1 Quote Link to comment Share on other sites More sharing options...
Woodmaster1 Posted February 1, 2019 Report Share Posted February 1, 2019 I am using my drill press and a variable speed delta grinder for my sanding. I also have a spindle sander, disk belt sander and a ridgid oscillating sander. You might say I am sander poor. My lathe is for turning only. SCROLLSAW703 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted February 1, 2019 Report Share Posted February 1, 2019 4 hours ago, Rolf said: Great idea! This is my traveling mop that I take to our wood working shows. Hi Rolf. I have a Klingspoor mop but what is yours called? SCROLLSAW703 1 Quote Link to comment Share on other sites More sharing options...
SCROLLSAW703 Posted February 2, 2019 Report Share Posted February 2, 2019 I'm kinda in about the same boat, Woodmaster. I've 3 palm sanders and a ROS I use for the biggest share of my scroll saw project sandin'. I've got two Dremels I rarely use for tight spot sandin', if I need to. I make my glue ups just wide enough to fit my 12 1/2" Griz planer. If I am doin' a larger project that requires more than one or two glue ups, I make them so that when the final glue up is done, I will have the total project size. In the meantime, after each glue up sets clamped over night and I have all the pieces, I run them all thru the planer down to the same thickness, then run the pieces thru the drum sander to smooth out any snipe, and splintered spots. Then those pieces go to the project table for finish sanding, cleaning, tape and pattern placement. It sounds complicated, I reckon, and lots of planin' & sandin', but when yer shop ain't but 400 sq. ft.and full of "toys", ya take things in steps, and work everything ya can for certain projects all at once when possible to prevent setbacks. My lathes do not get used for anything but lathe work. Otherwise, they set covered up in the shop. Sawdust703(brad) Rolf 1 Quote Link to comment Share on other sites More sharing options...
Rolf Posted February 2, 2019 Report Share Posted February 2, 2019 Rockytime , yes it is the 2" spindle mount mop from Klingspore. I love em. Sawdust, When I first started doing Intarsia I used a set of pneumatic drums in my Lathe. The problem with that is it is up too high, also I don't like working with a vertical drum on a drill press. So after a visit with Judy Gale Roberts I built my own pneumatic drum sander setup. Quote Link to comment Share on other sites More sharing options...
Rockytime Posted February 3, 2019 Report Share Posted February 3, 2019 It looks really good! Quote Link to comment Share on other sites More sharing options...
