scrollingforsanity Posted February 26, 2019 Report Posted February 26, 2019 Just making conversation to see what direction most of you scroll Clockwise or Counter clockwise. I am sure it is a personal preference. Many years ago when I first started scrolling there was not much for blades except Olson. I read somewhere that due to them being stamped in production the best direction was clockwise. Now with all the blades on the market it does not seem to matter as much which direction you cut. I still cut clockwise about 98% of the time due to habit. But as I am using Pegas MG and Flying Dutchman I find myself cutting both directions and don't see a lot of difference especially with the Pegas MG. Mostly cutting puzzles and stack cutting Ornaments. grizz OCtoolguy 1 Quote
kmmcrafts Posted February 26, 2019 Report Posted February 26, 2019 I cut counter clockwise most times but do cut both directions.. especially when I drill a whole in the wrong spot and clockwise would hold the piece better from breaking, LOL.. I'm not sure why I chose counter clockwise because I used to always cut clockwise when I first started cutting.. But when I first started I was also using Olsen blades.. Then I started using FD-UR blades for a lot of years.. and still do at times... but also use Pegas MG a lot ore now too.. OCtoolguy 1 Quote
Scrappile Posted February 26, 2019 Report Posted February 26, 2019 When you say clockwise- counter clockwise I get confused.... Do you mean do I move the wood clockwise or counter clockwise or are you talking the direction the blade is cutting??? I normally turn the wood counter-clockwise.. OCtoolguy 1 Quote
barb.j.enders Posted February 27, 2019 Report Posted February 27, 2019 I try to keep the pattern line to the right of my blade so not sure what direction I cut OCtoolguy 1 Quote
Sycamore67 Posted February 27, 2019 Report Posted February 27, 2019 I put the blade in backwards so that I can pull the wood instead of pushing it. Rockytime and Roberta Moreton 1 1 Quote
barb.j.enders Posted February 27, 2019 Report Posted February 27, 2019 2 minutes ago, Sycamore67 said: I put the blade in backwards so that I can pull the wood instead of pushing it. That sounds interesting - does it give you good control?? OCtoolguy 1 Quote
WayneMahler Posted February 27, 2019 Report Posted February 27, 2019 Cutting any pattern will have you cutting in both directions. I let the pattern dictate the direction. Old Joe, JTTHECLOCKMAN and OCtoolguy 1 2 Quote
kmmcrafts Posted February 27, 2019 Report Posted February 27, 2019 The direction you cut plays a big role in how the project comes out.. especially doing double bevel inlay work.. OCtoolguy 1 Quote
BigBubbaG Posted February 27, 2019 Report Posted February 27, 2019 I cut both ways but am much more comfortable going counter clockwise OCtoolguy 1 Quote
OCtoolguy Posted February 27, 2019 Report Posted February 27, 2019 I pretty much cut clockwise turning the wood counterclockwise. Unless, as Kevin said, I'm doing double bevel work. Quote
Fran L Posted February 27, 2019 Report Posted February 27, 2019 I generally cut clockwise but I'm comfortable enough counter-clockwise if the pattern dictates it. OCtoolguy 1 Quote
Rockytime Posted February 27, 2019 Report Posted February 27, 2019 I generally turn the wood counterclockwise but it mostly depends on the pattern. I also have become partial to the Pegas MG blades. Mounting the blade backwards and pulling is beyond me. Perhaps this was in jest. OCtoolguy 1 Quote
scrollingforsanity Posted February 27, 2019 Author Report Posted February 27, 2019 you got it figured out Paul you are cutting clockwise. Made for some interesting conversation anyway. not sure about putting the blade in backwards either, although I do quite often and have to turn it around. Old age I reckon. I was watching Kevin cut in one of his videos and he was cutting counter clockwise that's what made think of asking everybody. grizz OCtoolguy 1 Quote
crupiea Posted February 27, 2019 Report Posted February 27, 2019 I start my projects at the bottom right and work from right to left. I turn the wood counter clockwise. OCtoolguy 1 Quote
lawson56 Posted February 27, 2019 Report Posted February 27, 2019 Clockwise,but I to can go both ways. OCtoolguy 1 Quote
Sycamore67 Posted February 27, 2019 Report Posted February 27, 2019 (edited) Did anyone note the funny face winking and smiling after my backward blade comment....wink, wink wink.....of course it was in jest. Edited February 27, 2019 by Sycamore67 Scrolling Steve and kmmcrafts 2 Quote
Bill WIlson Posted February 27, 2019 Report Posted February 27, 2019 (edited) 12 hours ago, WayneMahler said: Cutting any pattern will have you cutting in both directions. I let the pattern dictate the direction. ^^^^^ This Many years ago, my Dad taught me to swing a hammer and use a circular saw with either hand. He told me that on a jobsite, you don't always have the luxury of being able to easily use your dominant hand. Kind of apples and oranges, but I think the basic premise applies here. Sometimes when the blade is fresh, it will cut a little more aggressively on one side than the other. Depending on the detail of the pattern and the room for error, I may use this to my advantage. I think it's good practice for all scrollers to be comfortable cutting in either direction. Edited February 27, 2019 by Bill WIlson OCtoolguy and stoney 1 1 Quote
dennis123 Posted February 27, 2019 Report Posted February 27, 2019 Unless forced by pattern constraints, my rule-of-thumb is the keep the 'waste' part of the wood on the left side of the blade. I guess that means I cut counter-clockwise. Quote
bcdennis Posted February 27, 2019 Report Posted February 27, 2019 Clockwise, unless of course the blade breaks somewhere near my starting point then I will go counter clockwise if it's shorter. OCtoolguy 1 Quote
JimErn Posted February 27, 2019 Report Posted February 27, 2019 I generally start the wood couterclockwise, but the pattern really dictates it OCtoolguy 1 Quote
teachnlearn Posted February 28, 2019 Report Posted February 28, 2019 In a digital world, how do you figure out counter-clockwise and clockwise? meflick and OCtoolguy 2 Quote
wombatie Posted February 28, 2019 Report Posted February 28, 2019 I keep the fall out part to the left of my blade 99% of the time. Marg OCtoolguy 1 Quote
BigBubbaG Posted February 28, 2019 Report Posted February 28, 2019 I wonder..... Does being right or left handed have anything to do with cut direction? I usually cut counter clockwise, (turning my piece clockwise) and I'm right handed. OCtoolguy 1 Quote
Rob Posted February 28, 2019 Report Posted February 28, 2019 20 hours ago, Sycamore67 said: Did anyone note the funny face winking and smiling after my backward blade comment....wink, wink wink.....of course it was in jest. Yes, but I have on one occasion done just that when cutting a large piece that was too big to turn on my saw. It can be a useful trick to get you out of a bind. Rob Quote
Norm Fengstad Posted February 28, 2019 Report Posted February 28, 2019 I am an either or person, but I did do a relief cutting, started counter clockwise and finished it up clockwise , didn't work out but gave laugh at myself Old Joe 1 Quote
