sullyscroller Posted December 8, 2010 Report Posted December 8, 2010 I've been using water based clear finish on most of my stuff for years now . I like it for three reasons 1st its less expensive than say Deft or other laquer finishes & 2nd I use a spray gun to do my finishing so cleanup is fast & i dont have to buy mineral spirits or figure out what to do with the used spirits , I just throw the water out on my gravel drive, Lastly the fumes from water based don't leave me in the clouds, when i spray i can be out in my shop for hours . Has anyone else used this and had any long term experience or drawbacks besides it raising the grain slightly ? Quote
PawPawRay Posted December 9, 2010 Report Posted December 9, 2010 What type of water based clear finish? I hate the smell of laquer. Quote
sullyscroller Posted December 9, 2010 Author Report Posted December 9, 2010 I use olympic sanding sealer for my first coat then use clear gloss after that .both are water cleanup and the fumes are not toxic . i buy both types at lowes by the gallon and spray it on . Quote
mikesscrollsaw Posted December 20, 2010 Report Posted December 20, 2010 what kind of spray gun are you using? I'd like to get away from the laquer if it's possible, water based would be so much easier for the reasons you mentioned. plus my shop is in my garage, which is attached to my house and when I spray paint or clear coat my whole house smells like that stuff. I use a respirator and open the door but it still stinks up the whole house. ever use water based paint through your spray gun? if so tell us about it. some of my projects have required a colored back ground (multiple layer fretwork project) and again I hate spraying with toxic paints. thanks Mike Quote
sullyscroller Posted December 25, 2010 Author Report Posted December 25, 2010 Sorry it took so long to reply been cutting for christmas . Ok the first coat i use Olympic sanding sealer ,it is water based . I let it dry for a few hours or till the next day the sand lightly . Water based does tend to raise the grain slightly but a quick sanding with 220 grit on my orbital does the trick. Then for my second coat i use Minwax water based Polycrylic clear gloss . Usually one coat of the minwax is all it takes . It goes on with a little milky look but dries clear. To make sure i get perfect coverage i have a clip on light shining down on what im spraying and i use the reflection to make sure there are no "holidays". This coat i give at least 8 hors before i handle it, I hate fingerprints. The spray gun i use is a Cambell Hausfeld but any good spray gun will work. Mines the 1 quart can style. Ive found that useing 30 psi works best but lower psi works too. I make the spray pattern as tight as possible .for cleaning i spray three different times at 90 psi changing the water each time. thats what works for me and the fumes are zero ,as far as the black background i have sprayed the minwax right over latex paint with no problems. Ron Quote
mikesscrollsaw Posted January 5, 2011 Report Posted January 5, 2011 I gave this a try today. Bought an Earlex HVLP spray system model 5000 for $250 and sprayed minwax polycrylic. So far so good, but I've got lots of experimenting to do! 2 things I noticed real quick are the house doesn't stink and the spray gun covers a large area really quickly. Quote
sullyscroller Posted January 5, 2011 Author Report Posted January 5, 2011 you can dial in your spray pattern to keep from having to much overspray also , try different pressures if you can to see what works best for you . Quote
mikesscrollsaw Posted January 7, 2011 Report Posted January 7, 2011 with this HVLP system you can't adjust the air pressure, it's a constant 10psi. however the gun is highly adjustable (at least based on my novice experience anyway) I found that using the more centered pattern instead of the horizontal or vertical fan pattern works really well. at first I was putting too much clear on and getting runs, but I've dialed it in pretty good now and I'm really liking this thing! Quote
sullyscroller Posted January 7, 2011 Author Report Posted January 7, 2011 Try using a clip on light to make sure you get even coverage using the reflection to see how much you put on . Also i took a piece of osb and shot brad nails true to set my pieces on as they dried . It holds them up and they don't stick on the bottom, so i spray btm first then flip it and spray the top.Ron Quote
mikesscrollsaw Posted January 7, 2011 Report Posted January 7, 2011 I did the brad nail board too, it works great. I'll go get a clip on light, my garage (shop) has flouresant tubes and it's kinda shady where I have the finishing area setup. Quote
