teachnlearn Posted March 10, 2019 Report Share Posted March 10, 2019 Just watch the video. RJF https://www.instructables.com/id/How-to-Double-Scrollsaw-Blade-Life/ jollyred and bobscroll 2 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted March 10, 2019 Report Share Posted March 10, 2019 Works for top loaders. I'm a bottom feeder. The guy is thinking though. Interesting. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted March 10, 2019 Report Share Posted March 10, 2019 Why go to all the trouble of making the auxiliary table to the same shape as the original table top, doesn't have to be. Cut a notch for the clamp leave the table top a rectangle. New teeth plus a bigger table top... @Rockytime why can't you do this as a bottom feeder? What you don't get is the reverse teeth in you were using a reverse teeth blade. Just means more fuzzies to clean up. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
John B Posted March 10, 2019 Report Share Posted March 10, 2019 I have used this method for years. Especially when cutting our native hard woods, the teeth blunt really quickly. I have found that it is not so successful on spirals though as when they are blunt they are just about buggered and by lifting up the table I only get another couple of minutes before they break. I have a 3/4" table cut slightly over size and the same shape as my Dewalt. It has a build up around the bottom so it fits snugly on the original table and dosen't move. For the Ex21 I just use an over sized piece of 3/4" melamine MDF and a couple of baby clamps to hold it in place. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
NC Scroller Posted March 10, 2019 Report Share Posted March 10, 2019 Blades cost me roughly 20-25 cents a piece. Seem like a lot of work and effort to save 10-13 cents. Scrappile, oldhudson, Sycamore67 and 2 others 4 1 Quote Link to comment Share on other sites More sharing options...
CharleyL Posted March 10, 2019 Report Share Posted March 10, 2019 52 minutes ago, NC Scroller said: Blades cost me roughly 20-25 cents a piece. Seem like a lot of work and effort to save 10-13 cents. +1 Charley Sycamore67, OCtoolguy and Scrappile 2 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted March 10, 2019 Report Share Posted March 10, 2019 IF, one uses the flying Dutchman Ultra Reverse blades.. the simplest thing one can do is simply put the blade in upside down and use the other end.. you still get reverse teeth as they run throughout the length of the blade anyway.. It may cut slightly slower due to the fact the in the saw the correct way i believe they have two teeth down and one up.. reversing it will give you two up one down, LOL.. but.. sharp teeth.. Like the others.. I simply toss a blade out as they are pretty cheep when buying bulk.. I might not do this if I was buying at $8 a dozen from the hardware store though... Makes a big difference in price.. and many many people do not know about gross buying.. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
stoney Posted March 10, 2019 Report Share Posted March 10, 2019 Depending what type of project you are cutting you can accomplish a similar result by cutting 3/4" off the bottom of the blade reinstall and readjust the tension. Not recommended for cutting where a perfectly perpendicular cut is required like for puzzles for example. I had a situation one time where I had some blades breaking off almost immediately about 1/4 - 3/8 inch from the end of the blade. I decided to try putting one back in the clamp and adjust the tension and try again and it worked great for the type of cutting I was doing. John B and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
fredfret Posted March 11, 2019 Report Share Posted March 11, 2019 Buy crown tooth blades when it dulls reverse it. Cost is about 20-35 cents per blade. I don't like the way they cut either way nut if blade life is the issue well. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
