Jet Band Saw
smitty0312
Looks in good shape and well kept. That is about a $500- $600 saw new when it was made. The thing that for me is that probably has a 3/4hp motor and this is fine for light work. 1hp or better is what I would want because I resaw my own lumber. Also a setup where I can change speeds. I say these things because I own the cousin to that saw which was Delta and I would want to upgrade. If you do not have a saw already then it can work for you. I would offer a lower price though.  But looks in great shape but hard to tell about the blade guides and finer things from a photo.
No fence included.....he wouldn’t budge from $350
No fence is needed. I did not have the factory fence. I use either my own built or a Carter magnetic fence. That is your call on what to do. Good luck.
No there is no riser on that saw. Not sure if that backbone is one piece or split because the switch is in the way. On my Delta it was split so I added the riser. From what I can tell it looks solid and not split.
Edited by JTTHECLOCKMAN
The saw looks quite similar to the Wilton  No. 8201 I bought last fall for $300. which was made by the same parent company.   The table looks identical.   Yes there is a split in the frame you can see the bolt it is below and to the right of the switch.    A riser kit could be installed but I would be reluctant to do so as it is a 3/4hp model.   As far as a fence many options are available.
13 hours ago, tgiro said:
As long as the wheel bearing are good and it tracks true, that's a good buy. You might want to see if Carter has a stabilizer to fit it.
Speaking of the Carter add-on, do you feel that it is that much of an improvement over the stock blade guides to warrant the cost? Almost as much as the cost of my saw ($350). I always wondered if they really helped that much to pry the money out of my wallet.
You're talking about the Carter Guides, which would replace the cool-block guide with bearings. And you're right - they are expensive, If I was doing it I would go with the bearing guides over cool-blocks every time. But I wasn't talking about that.
I was recommending the stabilizer -- https://www.carterproducts.com/band-saw-products/band-saw-stabilizer
The stabilizer literally lets you do scroll saw like cuts on a band saw. And it is much cheaper than a set of guides. Here is a bunch of youtubes about what the stabilizer is and what it does -- https://www.youtube.com/results?search_query=carter+bandsaw+stabilizer+
Thanks, I wasn't aware of the "stabilizer". Interesting.
