Floor underlayment is typically Luan, I just bought a square of it to demonstrate Pyrography. I would only use it as a backer on certain projects.
The 1.5mm (1/16)  50" x 50" for $44.70    that equals $2.50 a sq ft.  I use that for my 4" x 4" ornaments (30 cents). I sell the ornaments for $10-$12
The 3mm (1/8)  is only $15 for the same size sheet.  $.60 a sq ft.  That is used for larger fretwork projects. It is good one side but I rarely find any football patches on the back.
I also pre-sand all of my ply to 320.
The 2 x 2 x 1/8 Luan that I bought from Lowes cost me over $4  so not so cheap.
On 3/15/2019 at 8:14 PM, Woodmaster1 said:
I get mine the same place as Kevin in Charlotte MI at Johnson's Workbench. I am going to class on crown boxes tomorrow and also stopping at Johnson's Workbench to pickup some Baltic Birch before going to the class.
What are crown boxes?
They are round shaker boxes a cherry box and a maple rim attached with brass pins holding the rim to the top of the box. The name crown box was coined by Scott Phillips we he was having lunch with John Wilson the shaker box guru at least that's the story John told. I will add pictures when I get my set finished. There was a several people there taking the class so I took mine home to finish. The maple bands were getting stain from the cherry so wanted the white maple rim to be white. The crown term came from the rounded brass pins around the top. Here's a picture without the bottoms or rims.
Edited by Woodmaster1
7 hours ago, Rolf said:
If you are looking for stuff that looks like wood. I would get some wood.😉
I  bough two 1/4" X  2 X 2'  regular ply at Lowe's for backers.  I will need to sand them, as they are rough.  We have 2 Menard's stores, each about 15 miles away.  Went to the one that usually has better quality.  Their best piece wasn't even good enough to be called fire wood.
jerry
I bought Baltic Birch 1/4" plywood at Johnson's Workbench for 15.95 for a 5'x5' sheet. The Baltic birch is the best I have found. So if your close to South Bend IN or Charlotte MI it's worth the trip. I am about 90 miles from either one. The trip to Charlotte is an easier drive.
19 minutes ago, Gonzo said:
Jerry, not sure if you checked the "craft wood" area at Menards. That is where you'll find good BB. Also, 11% off this week.
I checked the craft wood & didn't find anything I wanted.  The 11% is quite often, but it is credited to your next purchase.  Lowe's on the other hand takes 10% off of anything in the store for us Veterans without question.  They enter your phone # one time and after that, each time you buy anything, you just give your #.
I buy 1/4" X 1 1/2" solid oak from Menards.  Theirs is better than Lowe's.
jerry
