Popular Post Denny Knappen Posted March 19, 2019 Popular Post Report Posted March 19, 2019 I saw this in his email last week and thought I would make one. I enlarged the pattern by 15% to make the basket just under 6" square and 2 1/2" high. The sides are 1/4" Baltic Birch plywood and the top and bottom are Mahogany. I used FD Polar #5 blades as I stack cut 4 pieces. Finished with spray Shellac. Getting each layer lined up when gluing was the hardest part. Comments welcome. lawson56, meflick, spotsdad and 10 others 13 Quote
Denny Knappen Posted March 19, 2019 Author Report Posted March 19, 2019 1 hour ago, Foxfold said: Beautiful Thanks Brenda. I like the looks of the plywood. Quote
Foxfold Posted March 19, 2019 Report Posted March 19, 2019 58 minutes ago, Denny Knappen said: Thanks Brenda. I like the looks of the plywood. It does give it a 'dramatic' look, I love it. Quote
Denny Knappen Posted March 19, 2019 Author Report Posted March 19, 2019 14 minutes ago, rjweb said: Another fine job Denny, RJ Thanks RJ. Quote
lawson56 Posted March 19, 2019 Report Posted March 19, 2019 Awesome job!!Lineing them up was always the hard part for me as well.I have only made a few. amazingkevin 1 Quote
Denny Knappen Posted March 19, 2019 Author Report Posted March 19, 2019 9 minutes ago, lawson56 said: Awesome job!!Lineing them up was always the hard part for me as well.I have only made a few. Thanks Bobby. This took a full sheet of 12" x 24" plywood. amazingkevin and lawson56 2 Quote
lawson56 Posted March 19, 2019 Report Posted March 19, 2019 1 minute ago, Denny Knappen said: Thanks Bobby. This took a full sheet of 12" x 24" plywood. Your Very Welcome.The one I did took about 1/2 a sheet,it was several yrs back. Quote
amazingkevin Posted March 20, 2019 Report Posted March 20, 2019 Precision alignment is what you are now good at!!! This is a gotta have at a craft show !!! Quote
JTTHECLOCKMAN Posted March 20, 2019 Report Posted March 20, 2019 Came out very nice. Very easy to get aligned and keep aligned if you make a jig. All it would be is 2 pieces of wood at a 90 degrees to each other. Now lay your pieces in the corner and they should all line up if you cutting is good. I would glue that group up first and then add the top and bottom. Easier that way because of the various curves. Quote
RabidAlien Posted March 20, 2019 Report Posted March 20, 2019 Nice!!! I just finished cutting this same pattern last night, just need to decide what stains to use. Quote
Denny Knappen Posted March 20, 2019 Author Report Posted March 20, 2019 11 hours ago, JTTHECLOCKMAN said: Came out very nice. Very easy to get aligned and keep aligned if you make a jig. All it would be is 2 pieces of wood at a 90 degrees to each other. Now lay your pieces in the corner and they should all line up if you cutting is good. I would glue that group up first and then add the top and bottom. Easier that way because of the various curves. Thanks John. I just used the eyes to make sure it was aligned. JTTHECLOCKMAN 1 Quote
Denny Knappen Posted March 20, 2019 Author Report Posted March 20, 2019 9 minutes ago, RabidAlien said: Nice!!! I just finished cutting this same pattern last night, just need to decide what stains to use. I didn't use any stains, just spray Shellac. Show pictures when finished. RabidAlien 1 Quote
RabidAlien Posted March 20, 2019 Report Posted March 20, 2019 Just now, Denny Knappen said: I didn't use any stains, just spray Shellac. Show pictures when finished. I cut my top and bottom pieces out of the same BB ply that the weave was cut from. I'll probably just keep them natural and rattlecan varnish them, and stain the top and bottom pieces a dark walnut. I'll post the finish pics in the Monthly Challenge thread, probably. Quote
