EXCITED!  I am anxious to read your opinion after some use.  You are a pretty dedicated DeWalt fan, so your opinion will be interesting.  Nothing in my mind against DeWalt saws, I owned one, but I thought the Excalibur was a definite step up.  I look forward to reading your view.
That is a beautiful looking saw.... unless you like yellow better.
Edited by Scrappile
I look forward to putting it to the test.  Yep, I'm a happy DW user and I know how long each one will last.  The Pegas will need to last at least 2 1/2 years to be considered "better" than the DW as far as durability.  Maybe the Pegas will be so smooth and sweet I'll never go back.  😉
You will notice a definite difference Iggy. I have one of each and can tell you that for sure. Especially if Pegas tuned it prior to shipping it. They are a great manufacturer.
Step 2 complete... base built, mounted and power tested.  The stand is quite a bit lower than the one I'm used to with the DW.  Certainly not a problem, my chair is height adjustable.
Step 3 will be performing some cutting tests (specifically related to puzzle pieces sliding in and out from both sides).
Reminder, I have a day job (work from home) so I have to sneak into the garage in between conference calls.  🙂
29 minutes ago, stevan said:
Steve Good showed a way to protect your table with magnetic sign material.  Have you given any thought about going that route?
I haven't thought about doing that at this point.  I've always just used the raw tables, but it's something I'll keep in mind.  I do wish they hadn't used a sticker on the table top that left residue after removing it...  Again, no big deal, some Goof Off took care of it.
Congrats on the new saw!  I've tried friend's Hawks and Hegners, plus have had Excaliburs and a Jet, but DeWalt is still my favorite.  BUT....really don't care for the yellow, so this past winter when we were snowed in for over a week, I got bored and painted one of them.  Masked off a few things and hit it with 3 coats of Rust-Oleum Cranberry, then 2 coats of spray lacquer.  Sure is pretty!  Everything that was black still is, just painted the  yellow, and the ugly orange on-off switch.  Noticed on one of my newer saws that the switch is  burgundy rather than orange, so maybe they thought that was ugly too.
Hope you get lots of use out of your new toy.
Report #1 -
Cut a test puzzle, all is well.  Just a minor adjustment to the tilt of the table to get it aligned and a minor shift of the table top so the blade was centered in the hole in the table.
Moved the saw into my cutting area and realized... Hmmm, no light... I loved the attached light on my DW.  I took a look at the Pegas and tried something... and it worked just fine... Using my DW light, just screwed on with one screw and the bolt shown props it in place.  Quick and easy fix.
Next is to do another puzzle with the vacuum system hooked up... It's all so exciting.  LOL
Edited by Iguanadon
