Iguanadon Posted March 21, 2019 Report Posted March 21, 2019 (edited) I figured I'd create a new thread for the actual review for folks that may try to search on it later. Pegas Saw Review - Initial Thoughts: As I begin using the new Pegas saw, I’ll report things that I notice. Not necessarily saying they are “good” or “bad”, but things I notice compared to heavy use of the DeWalt 788 the past 4 years (For those that don't know me, I wear out a DW every 12-15 months). I’ve only cut 6 puzzles today since setting it up. So I’m sure I’ll have more to report over time. The big test for me will be if I’m still using this saw in 3 years as that's the major test... longevity… I’ll report back in March of 2022. - Pegas saw runs very smooth, no vibration - There is a micro-second hesitation from when I press my foot pedal and the motor actually starts. Certainly not a big deal but I didn’t realize how often I’d just “bump” the saw sometimes to move the blade just a hair and can’t quite do it the same way now, just have to get used to that. - I bottom feed and the upper arm on the Pegas rises way out of the way and stays, very nice. If you feed from the top I think it could be less desirable due to having to feed the blade through the plastic membrane that is underneath the table which catches saw dust for sucking out with the vacuum system. - The Pegas blade chucks are excellent, as many folks already know and use on other saws. The hold tension nicely. - The vacuum system works very well. No dust falls from underneath. Now if only they could have it suck up the dust from the top. - Definitely need an optional light that attaches to the saw. I was able to rig up my DW light to use, but one specifically for the Pegas would be ideal. - There is not much table space at the front, between me and the blade. Not a big deal, just a noticeable difference. - Because I never use the tilt feature on saws I can’t really report on that, but from what I’ve heard and read, it’s a nice feature. -Last but not least... the Pegas does not cut quite as aggressively (fast) as the DW, but it's close enough. Much better than the Hawk that I purchased and couldn't adapt to. I'll definitely be able to live with this. Edited March 21, 2019 by Iguanadon UncleApple, NC Scroller, WayneMahler and 3 others 5 1 Quote
NC Scroller Posted March 21, 2019 Report Posted March 21, 2019 Thanks Scott for the updates. The table is just like my EX-21. When I first got it I thought it could use another inch up front but I don't notice it now. To me an attached light is a non issue. My eyes are to the point where a magnifier light is preferred. You will get there one day I am sure. Iguanadon and OCtoolguy 2 Quote
Iguanadon Posted March 21, 2019 Author Report Posted March 21, 2019 Ah, and one thing I forgot to mention... The Pegas is not as aggressive in cutting as the DeWalt, which I expected, but it's much better than the Hawk I tried and gave up on. I'll definitely be able to live with this. (I'm going to include this in the original content above for future readers) OCtoolguy 1 Quote
OCtoolguy Posted March 21, 2019 Report Posted March 21, 2019 54 minutes ago, Iguanadon said: Ah, and one thing I forgot to mention... The Pegas is not as aggressive in cutting as the DeWalt, which I expected, but it's much better than the Hawk I tried and gave up on. I'll definitely be able to live with this. (I'm going to include this in the original content above for future readers) Iggy, you can adjust it to cut more aggressively by turning the motor. Most of us try to take the aggression out of the saw but you might want to increase it. Quote
Iguanadon Posted March 21, 2019 Author Report Posted March 21, 2019 17 minutes ago, octoolguy said: Iggy, you can adjust it to cut more aggressively by turning the motor. Most of us try to take the aggression out of the saw but you might want to increase it. Good to know, thanks. I know when I tried setting the Hawk more aggressively it screwed up my puzzle pieces and they wouldn't slide in and out, so I'll debate whether to try it or not on the Pegas. OCtoolguy 1 Quote
OCtoolguy Posted March 21, 2019 Report Posted March 21, 2019 9 minutes ago, Iguanadon said: Good to know, thanks. I know when I tried setting the Hawk more aggressively it screwed up my puzzle pieces and they wouldn't slide in and out, so I'll debate whether to try it or not on the Pegas. Well, if you want more tilt to the saw blade you can dial that motor and get a lot of it. Me, I want the blade straight up and down as much as possible. I also noticed that by doing that, I got less vibration so I don't know what the trade off would be. Quote
kmmcrafts Posted March 21, 2019 Report Posted March 21, 2019 (edited) The tilt on the Pegas or like saws is not the same tilt you get with a Hawk... Just sayin.. Hawks tilt set up is not ideal for doing detail work.. The Hawk actually tilts the blade at an angle.. the Pegas and like saws will do more of a rocking motion.. I think you'll find you can make it just as aggressive as the DW and still make the puzzles correctly.. If your Pegas is like the Excalibur.. the blade speed is much less than the DW too.. EX is 1500 SPM and DW 1700 or 1750? Edited March 21, 2019 by kmmcrafts OCtoolguy 1 Quote
orangeman Posted March 22, 2019 Report Posted March 22, 2019 Now that you have a tilting head, how about making some bowls!!!!!!!! bb OCtoolguy 1 Quote
rjweb Posted March 22, 2019 Report Posted March 22, 2019 Thx for taking the time to inform us of your new saw, RJ OCtoolguy 1 Quote
hotshot Posted March 22, 2019 Report Posted March 22, 2019 (edited) I'm always trying to tune the aggression out of my saw, but once you learn to tune it, you will find you can take it to the extremes if you so desire. It will be interesting to see where you end up with this. Many folks remove the plastic dust collection membrane. I took mine off almost immediately. The membrane and the dust collection holes in the table are the only things I don't like about the design. Overall, I love these Taiwan saws, regardless of the Brand stuck to the side. The Pegas clamps do rock! Edited March 22, 2019 by hotshot NC Scroller, JimErn, Dave Monk and 2 others 4 1 Quote
UncleApple Posted March 22, 2019 Report Posted March 22, 2019 Appreciate the feedback! I'm supposed to get mine tonight. OCtoolguy and kmmcrafts 2 Quote
Old Joe Posted March 23, 2019 Report Posted March 23, 2019 Thanks for the review and feedback. I rebuilt my DW a few months ago, packed it with synthetic grease, and put Pegas clamps on it and it is a much better machine than it was when it was new. That said, I am still considering upgrading to a Pegas, mainly because I do a fair amount of relief cuts and want to do a lot more. OCtoolguy 1 Quote
Scrappile Posted March 23, 2019 Report Posted March 23, 2019 Interesting to read. Thanks for taking the time to do it. If nothing else, the Pegas wins the award for the prettiest scroll saw, in my book. Another way you may find to adjust the aggressiveness of the cut is try a little more aggressive blades on the Pegas. I know the same blade cuts differently on my Hegner than it does on the Seyco. The Hegner is less aggressive than the Seyco. I think if a person could fit the Seyco's big table (without the rectangular hole in it) on the Pegas saw, it would be about the only thing that could improve the Pegas. I never had a problem with the Excalibur table size, but the bigger one on the Seyco, is just nice to have. OCtoolguy 1 Quote
UncleApple Posted March 28, 2019 Report Posted March 28, 2019 Received my Pegas saw & stand a week ago Friday. Runs smoothly & quietly. Love the blade clamps & the fact that the blade tension is retained. The plastic membrane for dust collection, located underneath the table, came off on its own after about 6 hours of saw-use. I wasn't using the dust collection anyway and I'm sure it can be placed back on with some heavier duty glue / silicone. I feed from the top, so I'm kind of glad it's gone anyway because it is next to impossible to top-feed with it in place. Could definitely use a light...but couldn't all scroll saws? I don't notice the delay mentioned by Iggy from the time I step on the foot switch. Purchased it from bearwood.com. It's worth mentioning that their customer service is top-notch. Very friendly and helpful. They shipped the saw with a replacement tension lever which concerns me a little...do they wear out quickly??? They also shipped a pack of Pegas blades to try out which is great because I've never tried them. I found the stand a little frustrating to assemble, but you eventually figure it out. :) So far I'm VERY pleased with it. meflick, OCtoolguy and Iguanadon 3 Quote
NC Scroller Posted March 28, 2019 Report Posted March 28, 2019 58 minutes ago, UncleApple said: They shipped the saw with a replacement tension lever which concerns me a little...do they wear out quickly??? They also shipped a pack of Pegas blades to try out which is great because I've never tried them. I found the stand a little frustrating to assemble, but you eventually figure it out. So far I'm VERY pleased with it. When I got my EX-21 several years ago it came with a replacement tension lever direct from the factory. It was a General Tools made EX which I believe was made in the same factory that the Pegas saw is made in. OCtoolguy 1 Quote
Bill WIlson Posted March 28, 2019 Report Posted March 28, 2019 Got one with my EX-21 also. Which reminds me, I wonder where I put that thing? OCtoolguy 1 Quote
mprogler Posted March 28, 2019 Report Posted March 28, 2019 Thinking about getting one. I found three on-line vendors selling the Pegas. QTE, D&D, and Bearwood. Without shipping, all three are within about $60 of each other (including the $50 gift card from BW). Any likes or dislikes about customer service from these three? OCtoolguy 1 Quote
OCtoolguy Posted March 28, 2019 Report Posted March 28, 2019 11 minutes ago, mprogler said: Thinking about getting one. I found three on-line vendors selling the Pegas. QTE, D&D, and Bearwood. Without shipping, all three are within about $60 of each other (including the $50 gift card from BW). Any likes or dislikes about customer service from these three? Of the 3 named, I have had the best service from QTE and D&D. Because Bear is in Canada, everything takes longer. Depending on which side of the country you are in, I'd give either of those two my business. Quote
scrollerpete Posted March 28, 2019 Report Posted March 28, 2019 Even in Canada Bear Wood service and shipping cost are not that good, I would recommend D&D Dave Monk and OCtoolguy 2 Quote
Dave Monk Posted March 29, 2019 Report Posted March 29, 2019 5 hours ago, mprogler said: Thinking about getting one. I found three on-line vendors selling the Pegas. QTE, D&D, and Bearwood. Without shipping, all three are within about $60 of each other (including the $50 gift card from BW). Any likes or dislikes about customer service from these three? I got mine from D&D and love it. OCtoolguy and Scrolling Steve 2 Quote
UncleApple Posted April 2, 2019 Report Posted April 2, 2019 On 3/28/2019 at 2:35 PM, mprogler said: Thinking about getting one. I found three on-line vendors selling the Pegas. QTE, D&D, and Bearwood. Without shipping, all three are within about $60 of each other (including the $50 gift card from BW). Any likes or dislikes about customer service from these three? Bearwood customer service, in my humble opinion, should be industry standard for ALL customer service departments... OCtoolguy 1 Quote
