Actually it's probably not the saws fault, but over the years I've kept wearing out the Excalibur tension knob because I have the bad habit of pressing it down when inserting the top of the blade.  Not sure if there has always been this much play in the forearm, but it seems so.  Well I came up with a fix in the form of a lever that will hold the forearm down while I insert the blade allowing my knob to go untouched.  If you have this problem you might want to take a look.  I've done a YouTube video showing the problem and my fix for it.  If you have any thoughts on this I'd like to hear them.  You can also download the pattern for the lever if you have need of it from the link in the video description.
Edited by baggetta
I like your fix for that problem. But, and I don't say this lightly, a set of the new Pegas clamps for the EX style saws will eliminate all that. I also don't recall my EX having that much play in the upper blade clamp arms. Realizing you are not a novice, do you have the arm adjusted level to the table? And leave it there? I have mine adjusted level and never have to tough the knob in the rear. And I don't have any looseness in the arm mechanism. Maybe my saw is just not "broken in" as yours must be. By the looks of your saw table, your saw has seen a lot of cutting. Mine is very new looking. I bought it used but obviously it was not TOO used. Thanks for the great idea for a fix though.
Thanks for the comments.  I do use the saw a lot.  I've adjusted the arm but to no avail.  Still gives me a problem.  I do have a set of the new Pegas clamps and plan on installing when I get the most out of what I've got.  Over the 8 or 9 years that I've had the saw I think I changed the tension knob assemble about 4 times.  Thanks for the comments on the video.  I'm new at making videos, but I hope to get better with practice.  One thing I can't stand in most videos is the loud music that often accompanies the work being demonstrated.  Thanks again for your input. I appreciate it.
Al B.
12 hours ago, trackman said:
That is a good fix for you but I think you have a worn bushing in one or both ends of the arms. My EX 21 is 10 years old and has no movement in that area at all. Be good to hear from others. Maybe it is time for a tuneup.
Ditto, I have no idea how old my used one is, but there is no movement at all in what they call the rocker arm (item 27, highlighted, in the attached pic_.
Edited by JimErn
I agree. What I saw in the video is a saw with multiple problems. Time for a tear down/tune up.
Why are you pushing down on the knob?  When I sat in a session with Ray Seymore, he had us pushing down on the top of the arms with our left hand, while our left thumb hooked under and held the blade in the clamp. Then we tighten the knob with the right hand. That provides a straight down gentle pressure (you don't have to jam it down).
I can see how pushing down with the knob may provide some twist to the arms and throw something out of alignment over a period of time.
I've had my EX-21 for 7 years. I've used Ray's method when I had the OEM clamps and after I installed the Pegas Clamps. while there is a little play in the arms with no tension, they work fine once I lock the blade in place.
I have had that problem and still do to a minor degree. Part number (64) on the schematic that Jim posted is in two sections on my machine with and adjustment bolt holding the two together. By moving the bolt you can elongate or shorten the top arm. The important thing is to make sure that when it is adjusted the bolts must be tightened so there is no flex in the joint. flex allows the top rocker arm to move like in video.
