kmmcrafts Posted April 14, 2019 Report Posted April 14, 2019 Just ordered the plunge router for a Dremel.. and bought the WEN knock-off rotary tool and the mini drill chuck.. I've been wanting this set up for a long time now.. My drill press is getting pretty worn.. Probably going to have to replace it this year sometime.. but meanwhile I'm hoping to just use this for the small entry holes to take some of the wear off my drill press.. Total cost for all was just shy of $60.. OCtoolguy, davidg, tomsteve and 2 others 5 Quote
Woodmaster1 Posted April 15, 2019 Report Posted April 15, 2019 I bought a drill from seyco and it does a nice job drilling small entry holes. OCtoolguy and kmmcrafts 2 Quote
JTTHECLOCKMAN Posted April 15, 2019 Report Posted April 15, 2019 My opinion a Delta table top drill press would be a better way to go. kmmcrafts and OCtoolguy 2 Quote
JimErn Posted April 15, 2019 Report Posted April 15, 2019 I use that same set up and I prefer it over the drill press. Practice on a scrap with lines and intersections first, it takes a little getting used to. kmmcrafts and OCtoolguy 2 Quote
NC Scroller Posted April 15, 2019 Report Posted April 15, 2019 I used a similar setup for years until I found a radial arm drill press on CL. If you have the space that is the best solution especially for someone who does production work like you. OCtoolguy and kmmcrafts 1 1 Quote
kmmcrafts Posted April 15, 2019 Author Report Posted April 15, 2019 9 hours ago, Woodmaster1 said: I bought a drill from seyco and it does a nice job drilling small entry holes. I was looking at those but, they been out of stock for the last 6-8 months... and this is a cheaper option for now.. OCtoolguy 1 Quote
kmmcrafts Posted April 15, 2019 Author Report Posted April 15, 2019 7 hours ago, JTTHECLOCKMAN said: My opinion a Delta table top drill press would be a better way to go. This is what I have now... but it's getting an awful lot of slop in the quill and I believe it also has a bad bearing.. as it's getting quite noisy too.. I'll probably take it apart and try to see if I can repair it.. but first I want a back-up one.. will keep my eye out for another one on craigslist etc.. tomsteve and OCtoolguy 2 Quote
kmmcrafts Posted April 15, 2019 Author Report Posted April 15, 2019 50 minutes ago, NC Scroller said: I used a similar setup for years until I found a radial arm drill press on CL. If you have the space that is the best solution especially for someone who does production work like you. I've seen a few of those and wondered how they might work for this line of stuff.. I may have to look into it more.. OCtoolguy 1 Quote
Rolf Posted April 15, 2019 Report Posted April 15, 2019 (edited) Sounds like a nice solution. The tiny drills I use for my fretwork like to spin at high speed I don't like running my drill press that fast and constantly changing the belt positions. So when I realized I was in this hobby for the long run I bought a small dedicated drill press from Micromark. The price for these have gone up significantly from when I bought mine. If I was in the market for a new drill press I would probably go nuts and buy this one. https://www.woodcraft.com/products/dvr-voyager-18-drill-press I love the technology and since I have a Nova DVR lathe am impressed with the how smooth and powerful the direct drive system is. Lucky for me my drill press is fine. Edited April 15, 2019 by Rolf OCtoolguy 1 Quote
ike Posted April 15, 2019 Report Posted April 15, 2019 I use both the dremel and drill press it works fine that way for me. IKE OCtoolguy 1 Quote
JTTHECLOCKMAN Posted April 15, 2019 Report Posted April 15, 2019 3 hours ago, kmmcrafts said: This is what I have now... but it's getting an awful lot of slop in the quill and I believe it also has a bad bearing.. as it's getting quite noisy too.. I'll probably take it apart and try to see if I can repair it.. but first I want a back-up one.. will keep my eye out for another one on craigslist etc.. I have that setup and just about every option Dremel offers and use them on occasion for special jobs but they are not smooth and get to be a pain in the butt to drill with. Nothing like a good drill press. A drill press would be a better investment than a laser. OCtoolguy and kmmcrafts 1 1 Quote
Chunkthekid Posted April 15, 2019 Report Posted April 15, 2019 I do most of my holes with a dremel and dremel drill press. Works great, but on larger projects there are spaces it won't reach. Then I just use my trusty eyes to (hopefully) drill straight down by hand. I've been wanting a larger drill press for a long time and now that I have one, I honestly don't thing I will ever use it to drill pilot holes. OCtoolguy 1 Quote
kmmcrafts Posted April 15, 2019 Author Report Posted April 15, 2019 2 hours ago, JTTHECLOCKMAN said: I have that setup and just about every option Dremel offers and use them on occasion for special jobs but they are not smooth and get to be a pain in the butt to drill with. Nothing like a good drill press. A drill press would be a better investment than a laser. Actually you just reminded me.. I gotta set up my laser.. Who needs a drill press when you can just burn the holes with the laser OCtoolguy and JTTHECLOCKMAN 1 1 Quote
Rob Posted April 16, 2019 Report Posted April 16, 2019 What about the Seyco scrollers drill? Not available here and wrong voltage too but looks pretty good? Rob OCtoolguy 1 Quote
kmmcrafts Posted April 16, 2019 Author Report Posted April 16, 2019 6 hours ago, Rob said: What about the Seyco scrollers drill? Not available here and wrong voltage too but looks pretty good? Rob That's what I was going to buy late fall early winter last year.. they've been out of stock for ever.. and the price is about double the price of what this Dremel set up is costing me.. OCtoolguy 1 Quote
kmmcrafts Posted April 16, 2019 Author Report Posted April 16, 2019 Received the WEN and the plunge router attachment this morning.. mounted the WEN into the router and everything seems to work like it should.. just gotta wait for the mini drill chuck so I can use it.. Just playing around with it.. I think this is going to be an awesome setup.. I'm sure it'll take some time to get used to lining up the drill bit to the lines.. I'll do drilling on bigger fret cutouts until I get used to lining up etc for the small veining cuts etc.. OCtoolguy 1 Quote
Rockytime Posted April 16, 2019 Report Posted April 16, 2019 You'll love the Dremel set up. Mine works like a charm. OCtoolguy 1 Quote
rjweb Posted April 17, 2019 Report Posted April 17, 2019 Kevin how about some pictures when you get it all set up, RJ OCtoolguy 1 Quote
Scrappile Posted April 17, 2019 Report Posted April 17, 2019 (edited) "I Took The Plunge". Give me a break! I'm a little slow in the up tick, I just caught this morning. Edited April 17, 2019 by Scrappile OCtoolguy 1 Quote
kmmcrafts Posted April 17, 2019 Author Report Posted April 17, 2019 1 hour ago, Scrappile said: "I Tool The Plunge". Give me a break! I'm a little slow in the up tick, I just caught this morning. I wondered if anyone would say anything about that OCtoolguy 1 Quote
Dave Monk Posted April 17, 2019 Report Posted April 17, 2019 On 4/14/2019 at 9:49 PM, Woodmaster1 said: I bought a drill from seyco and it does a nice job drilling small entry holes. I have one also. I wish it was built a bet better. OCtoolguy 1 Quote
kmmcrafts Posted April 17, 2019 Author Report Posted April 17, 2019 6 hours ago, Sycamore67 said: No Pictures...... 14 hours ago, rjweb said: Kevin how about some pictures when you get it all set up, RJ Well here is a picture since you all asked lol. OCtoolguy 1 Quote
JTTHECLOCKMAN Posted April 17, 2019 Report Posted April 17, 2019 you have to be careful not to tip when close to edges. I use that for routing more than anything else. Good luck with it. OCtoolguy 1 Quote
Bill WIlson Posted April 17, 2019 Report Posted April 17, 2019 I wonder if one could attach a larger, supplemental base plate to that to help prevent tipping? It may not be very practical for routing, but may work for plunge drilling. OCtoolguy 1 Quote
