Rolf Posted April 28, 2019 Report Posted April 28, 2019 For picture frames it is not only a precise angle you also need precisely matching lengths of the opposite sides. OCtoolguy 1 Quote
Gonzo Posted April 28, 2019 Report Posted April 28, 2019 A very interesting thread. I too would like to make accurate angle cuts. And reading this thread got me thinking. So I started looking yesterday. My DeWalt mitre saw is awesome, but not for smaller pieces. I did find a mitre box from Lee Valley, it's a Nobex. Looks real nice. Went on Craigslist, found one locally, pondered buying, decided to go for it. It was sold! Bummer! Oh well, will have to buy new. OCtoolguy and JTTHECLOCKMAN 1 1 Quote
Scrappile Posted April 28, 2019 Report Posted April 28, 2019 (edited) Okay, good thread, but the miter is not the hardest part for me. It is gluing. You can cut a perfect 45° miter, but it won't be perfect if it is not glued squarely. I have a couple, maybe three gluing jigs. The last one I made does the best job, but it is cumbersome to set up. Okay for me because I may make 5 or 6 frames a year, but if I were to do more I would want something easier to set up. My current one is similar to this. The other part is fastening the picture into the frame. In the past I have always used little nails, and it looks pretty "tacky" (get it?) to me. Recently I purchased a Logan Picture frame tool. It works great. Edited April 28, 2019 by Scrappile OCtoolguy and Rolf 1 1 Quote
Gonzo Posted April 28, 2019 Report Posted April 28, 2019 Interesting jig ya got there Scrappile. I like it. Did you make it? And my apologies Rockytime for hi-jacking your thread. OCtoolguy 1 Quote
Scrappile Posted April 28, 2019 Report Posted April 28, 2019 (edited) 28 minutes ago, Gonzo said: Interesting jig ya got there Scrappile. I like it. Did you make it? And my apologies Rockytime for hi-jacking your thread. Yes, very sorry Les, I did kinda lost site of the reason for this thread. Just let me post the plans I used for my framing jig and I will bow out. I got the plans from this site. They have some good plans there: http://www.craftsmanspace.com/free-projects/adjustable-4-corner-framing-clamp-plan.html Adjustable 4 corner framing clamp plan.pdf Edited April 28, 2019 by Scrappile OCtoolguy and Roberta Moreton 2 Quote
JTTHECLOCKMAN Posted April 28, 2019 Report Posted April 28, 2019 (edited) I use belt straps and have several versions depending how large the frame is. I also agree the lengths must be exact for good tight joints. Stop blocks work well when cutting. I use my tablesaw. It is the most accurate saw in a workshop by far and that should be anyones workshop. Many jigs can be made to fit it and make things so much easier. So for me the tablesaw (well tuned) is the best tool in a workshop hands down. Many versions of these out there and they basically all work the same way. https://www.ebay.com/p/Rapid-Corner-Clamp-Band-Strap-4-Jaws-For-Picture-Frame-Holder-Woodworking-Drawer/3028633447?iid=173771235531 Edited April 28, 2019 by JTTHECLOCKMAN OCtoolguy 1 Quote
Rockytime Posted April 29, 2019 Author Report Posted April 29, 2019 8 hours ago, Scrappile said: Yes, very sorry Les, I did kinda lost site of the reason for this thread. Just let me post the plans I used for my framing jig and I will bow out. I got the plans from this site. They have some good plans there: http://www.craftsmanspace.com/free-projects/adjustable-4-corner-framing-clamp-plan.html Adjustable 4 corner framing clamp plan.pdf 604.01 kB · 3 downloads Thanks for the web site and pdf. Interesting web site! OCtoolguy and Roberta Moreton 2 Quote
Rockytime Posted May 4, 2019 Author Report Posted May 4, 2019 I'm taking Scrappile's advice. Today I received my saw rails and started making my frame jig for my table saw. The Delrin strips work very smoothly. Tomorrow I'll add the angle strips. The Delrin strip was 48" and had a long curve in it but it worked. Scrappile and OCtoolguy 2 Quote
Scrappile Posted May 5, 2019 Report Posted May 5, 2019 (edited) you are taking my advice on things related to saws!!!!!!!!!??????????? Edited May 5, 2019 by Scrappile John B and OCtoolguy 2 Quote
Rockytime Posted May 5, 2019 Author Report Posted May 5, 2019 My saw does not have a riving knife so I always make it a practice to not stand directly in front of the saw. My saw is not real powerful but still throws material every once in a while. I feel bad for your experience. OCtoolguy 1 Quote
JTTHECLOCKMAN Posted May 5, 2019 Report Posted May 5, 2019 (edited) 1 hour ago, Scrappile said: you are taking my advice on things related to saws!!!!!!!!!??????????? Is this you and if so what happened?? Never mind I saw your other post. Good luck with that. Edited May 5, 2019 by JTTHECLOCKMAN Scrappile and OCtoolguy 1 1 Quote
OCtoolguy Posted May 5, 2019 Report Posted May 5, 2019 20 hours ago, Scrappile said: you are taking my advice on things related to saws!!!!!!!!!??????????? Wha the heck happened Paul? That hand looks bad. Scrappile 1 Quote
Scrappile Posted May 5, 2019 Report Posted May 5, 2019 It woudn't look quite as if the finger tips didn't look blue-gray... they are un s shadow makes them look like i have frost-bite!! OCtoolguy 1 Quote
Scrappile Posted May 5, 2019 Report Posted May 5, 2019 21 hours ago, Rockytime said: I'm taking Scrappile's advice. Today I received my saw rails and started making my frame jig for my table saw. The Delrin strips work very smoothly. Tomorrow I'll add the angle strips. The Delrin strip was 48" and had a long curve in it but it worked. I'd suggest, and maybe what you plan, but make your strips out of something like 1" x 2" stock. that way you can use clamps tp clamp the picture frame stock to. OCtoolguy 1 Quote
Rockytime Posted May 5, 2019 Author Report Posted May 5, 2019 2 minutes ago, Scrappile said: I'd suggest, and maybe what you plan, but make your strips out of something like 1" x 2" stock. that way you can use clamps to clamp the picture frame stock to. I just did as you suggested. I also bought toggle clamps from HF this morning. I just nailed the strips lightly to keep in position. Tomorrow I go to ACE for the proper length screws. Then the test to see it it is accurate. I am not a wood worker by any means. I perhaps should have used MDF but I don't like the weight altho it is more impervious to humidit changed. So far the sled slides smoothly. OCtoolguy and Scrappile 2 Quote
Scrappile Posted May 5, 2019 Report Posted May 5, 2019 16 minutes ago, Rockytime said: I just did as you suggested. I also bought toggle clamps from HF this morning. I just nailed the strips lightly to keep in position. Tomorrow I go to ACE for the proper length screws. Then the test to see it it is accurate. I am not a wood worker by any means. I perhaps should have used MDF but I don't like the weight altho it is more impervious to humidit changed. So far the sled slides smoothly. That will also allow you to clamp on stop blocks to make sure your frame pieces are the same length,,, you can see, i didn't really think things through when i built mine. maybe some day i will build another. but mine work good as is. OCtoolguy 1 Quote
OCtoolguy Posted May 5, 2019 Report Posted May 5, 2019 23 minutes ago, Rockytime said: I just did as you suggested. I also bought toggle clamps from HF this morning. I just nailed the strips lightly to keep in position. Tomorrow I go to ACE for the proper length screws. Then the test to see it it is accurate. I am not a wood worker by any means. I perhaps should have used MDF but I don't like the weight altho it is more impervious to humidit changed. So far the sled slides smoothly. I don't know if I'm doing something wrong but I can't get screws to hold in MDF. I'll stick to using good plywood. Quote
Scrappile Posted May 5, 2019 Report Posted May 5, 2019 Just now, octoolguy said: I don't know if I'm doing something wrong but I can't get screws to hold in MDF. I'll stick to using good plywood. correct, one more con for mdf. i have drilled a pilot hole then filled it with ca glue to strengthen the screw hole. that helps. i have also drilled a larger hole, glued in a dowel the screwed the screw into the dowel.... OCtoolguy 1 Quote
JTTHECLOCKMAN Posted May 6, 2019 Report Posted May 6, 2019 I make jigs of all kinds all the time. I use various materials but 3/4" plywood is great. I make oak runners so they keep straight and can glue to bottom of plywood before I nail them. OCtoolguy 1 Quote
Rockytime Posted May 6, 2019 Author Report Posted May 6, 2019 I did it. I made my miter sled. Very crude but seems to work. I just used what I had on hand with the exception of the toggle clamps which came from HF. It was somewhat of a struggle as I have a cheap saw with chintzy fence. I always use a framing square to make sure it is square with the table. There are things I will do different should I make another one which I probably won't. I wanted to make a rustic frame so I used a very rough cedar fence stake. I may never make another as my space is too crowded to work comfortably. OCtoolguy and Scrappile 1 1 Quote
JTTHECLOCKMAN Posted May 7, 2019 Report Posted May 7, 2019 Rocky never square any jig off any part of a tablesaw except the blade. Every measurement comes off the blade. Not the fence not the miter gauge, but the blade. Just a side note. OCtoolguy 1 Quote
Bill WIlson Posted May 7, 2019 Report Posted May 7, 2019 Proof is in the pudding Les, looks like you got pretty good results on your frame. Well done. Another little tip, You might want to take a little fine sandpaper and adhere it to the jig. You could put a strip on the fences or even on the base. This will help prevent the wood from creeping when you push it through the saw. OCtoolguy 1 Quote
Rockytime Posted May 8, 2019 Author Report Posted May 8, 2019 This is my finished frame. The cedar really rough and irregular in thickness but with decent wood it should work out well. I just wanted a rustic look. OCtoolguy 1 Quote
rjweb Posted May 8, 2019 Report Posted May 8, 2019 Very nice, we will be calling you the frame man, RJ OCtoolguy 1 Quote
