jerry1939 Posted June 3, 2019 Report Posted June 3, 2019 Because I am cursed with being a perfectionist, if I see something that doesn't hang straight, I go out at night and talk to the moon. Made a router jig for cutting a slot on the back of a hanging piece. Never got interested in saw tooth hangers, as a "tooth" was always in the wrong place. If you mount it up-side-down, there isn't much to hold your piece. Place a pencil mark on the piece where you think it should hang. (Figure "C") Figure A is the jig & B is for alignment. There is a 1/4" hole above the "B". Place the hole over the pencil mark. Remove "B". I use a 1/4" straight bit on the router. The opening in "A" is the size of the router base (top to bottom). Sid to side opening is 1 inch wider. jerry OCtoolguy and JimErn 1 1 Quote
JimErn Posted June 4, 2019 Report Posted June 4, 2019 Interesting way to do it - nice jig too, very creative, I generally use a keyhole router bit this show one way to do it, not sure how I wold get it done with a circular piece though https://www.wwgoa.com/article/using-a-keyhole-bit/ OCtoolguy 1 Quote
jerry1939 Posted June 4, 2019 Author Report Posted June 4, 2019 6 hours ago, JimErn said: Interesting way to do it - nice jig too, very creative, I generally use a keyhole router bit this show one way to do it, not sure how I wold get it done with a circular piece though https://www.wwgoa.com/article/using-a-keyhole-bit/ So far, I've only used it once. The 4th photo shows it demonstrated on the narrow end of an oval. Piece "A" shows that it has a "tail" that could be used for something narrow, i.e. a cross that has more weight on one side. Time will tell. jerry OCtoolguy 1 Quote
JTTHECLOCKMAN Posted June 4, 2019 Report Posted June 4, 2019 Making jigs for projects to make things easier and safer, many times is more enjoyable than the project itself. You get satisfacion you figured a way to solve a problem. I use many methods of hanging including sawtooth hooks and triangle hooks and even picture wire. For many of my shelves I used the keyhole router method and made various jigs for each type shelf. Works great. Quote
Woodmaster1 Posted June 6, 2019 Report Posted June 6, 2019 That is the router bit I use for cutting slots to make it easier to hang things straight. Awesome jigs for getting the job done! OCtoolguy 1 Quote
