Travis, I had some 8" wide poplar, yes, 1" (which is actually 3/4" for those who don't know the confusing way wood sizes can be :oops: )
The only thing they don't mention in the book is when you go to cut the basket part-at an angle-the HOLES should also be drilled at an angle. Otherwise, the book is very clear, and gives step by step instructions for bandsaws and scrollsaws. I actually use both-cut the straight lines quick with the bandsaw(like the base), sand it perfect with my disc sander,then cut the rest with the scrollsaw.
