Dave Monk Posted June 17, 2019 Report Share Posted June 17, 2019 Are you cutting the holes for clock inserts with a scroll saw or using forstner bits? OCtoolguy and new2woodwrk 1 1 Quote Link to comment Share on other sites More sharing options...
JimErn Posted June 17, 2019 Report Share Posted June 17, 2019 I only use the small clock insert so I use a forstner bit I made an inkscape template with the drawings for 3 clock inserts, then I just copy and paste to the new inkscape instance I am working on, let me know if you want it. new2woodwrk, OCtoolguy and Dave Monk 3 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted June 17, 2019 Report Share Posted June 17, 2019 5 minutes ago, JimErn said: I only use the small clock insert so I use a forstner bit I made an inkscape template with the drawings for 3 clock inserts, then I just copy and paste to the new inkscape instance I am working on, let me know if you want it. I sure would like a copy if possible - I have a bunch that need clocks and I've not gotten to them yet OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
scrollerpete Posted June 17, 2019 Report Share Posted June 17, 2019 41 minutes ago, Dave Monk said: Are you cutting the holes for clock inserts with a scroll saw or using forstner bits? I used Forster bits myself, perfect circle and easier. Dave Monk and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted June 17, 2019 Report Share Posted June 17, 2019 I also use forstner bits.. most of my clocks are the smaller ones but I do use the larger inserts that require a 3" forstner bit.. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rolf Posted June 17, 2019 Report Share Posted June 17, 2019 I don't like to see the back of the clock movements on my projects so for most of my inserts I use forstner bits and don't go all the way through, depending on wood thickness. For very large movements I use the scroll saw. Dave Monk and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
edward Posted June 17, 2019 Report Share Posted June 17, 2019 I also use a forstner bit for my small clocks, I have not made larger clocks. OCtoolguy and Dave Monk 2 Quote Link to comment Share on other sites More sharing options...
dgman Posted June 17, 2019 Report Share Posted June 17, 2019 I use Forstner bits also. I have one for all the popular insert sizes. I even have a 1 3/8” carbide tipped bit for the small inserts. It’s easy to sharpen! Dave Monk and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
JimErn Posted June 17, 2019 Report Share Posted June 17, 2019 1 hour ago, new2woodwrk said: I sure would like a copy if possible - I have a bunch that need clocks and I've not gotten to them yet it is attached clock-insert-template.svg new2woodwrk, OCtoolguy, Dave Monk and 2 others 1 4 Quote Link to comment Share on other sites More sharing options...
Frank Pellow Posted June 17, 2019 Report Share Posted June 17, 2019 I've only made one clock insert and, for it, I used a Forstner bit on my drill press. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted June 17, 2019 Report Share Posted June 17, 2019 I always use forstner bits. Easy and clean and easy to adjust the right depth. Dave Monk 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted June 17, 2019 Report Share Posted June 17, 2019 You have to get a lot of money for the clocks to pay for those larger forstner bits!! They are spendy! kmmcrafts, Dave Monk and OCtoolguy 3 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted June 17, 2019 Report Share Posted June 17, 2019 4 hours ago, Scrappile said: You have to get a lot of money for the clocks to pay for those larger forstner bits!! They are spendy! Yeah, good ones sure aren't cheap.. I bought a complete set several years ago when my bit I had used for a long time was getting dull. But the new bit in that cheap set was duller then the old one that I thought was getting dull, LOL... Don't waste the money on set's is something I was told when I first started making clocks.. just buy the sizes you need and in a quality brand.. I mainly only use 3 different sizes.. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
RangerJay Posted June 17, 2019 Report Share Posted June 17, 2019 Unless you are making a whack of clocks there are much cheaper (i.e. way more cost efficient) alternatives to Forstner bits - none of the clocks I have ever made is a production item - meaning I use hole saws very comfortably - and if I'm only making one clock I will likely use the scroll saw. Jay OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rolf Posted June 18, 2019 Report Share Posted June 18, 2019 21 hours ago, Scrappile said: You have to get a lot of money for the clocks to pay for those larger forstner bits!! They are spendy! Spendy? Forstner bits are a must have item in a wood working shop JMO. What size bit are you talking about? A 3" carbide bit is $50 on Amazon, a MLCS brand brand $21.(I have been pleased with their products) Any bigger than that I would use alternative methods, i.e. scroll saw, or router if I don't want to go all the way through. OCtoolguy and John B 1 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted June 18, 2019 Report Share Posted June 18, 2019 1 hour ago, Rolf said: Spendy? Forstner bits are a must have item in a wood working shop JMO. What size bit are you talking about? A 3" carbide bit is $50 on Amazon, a MLCS brand brand $21.(I have been pleased with their products) Any bigger than that I would use alternative methods, i.e. scroll saw, or router if I don't want to go all the way through. I use Peachtree bits along with MLCS bits and to me yes a complete set is a must if woodworking in a shop. I have a few complete sets and have sets up to 4" When using bigger bits you need a drill press and you need to slow it down. I do buy individual ones in sizes I use most and I have carbide ones in the 1-3/8" size because I drill billiard balls for clock inserts and that dulls a bit quickly. I have learned to sharpen them too which helps prolong the life. I would not be without them. Holesaws are fine but I usually do not want a hole to go all the way through the back side if possible. Same with scrolling them. Jim McDonald, John B, RangerJay and 3 others 5 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted June 18, 2019 Report Share Posted June 18, 2019 I use Freud brand.. maybe a bit more pricey brand? Not sure since I never really priced them.. It's what my local tool supplier carries and they also service them (sharpen ) etc.. I mainly use the 1-3/8 and 2-3/8 and 3 inch ones.. I do have a complete set also of the cheapy set from Menards that goes up to I think 2-3/4 inch.. They do work.. but nothing like the good ones.. I'll use them when / if I have mine sent out for sharpening.. funny thing though.. I've never had to send them out yet.. I'm sure they maybe getting dull.. but nothing like as dull as the new ones in the set, LOL OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rolf Posted June 19, 2019 Report Share Posted June 19, 2019 Jt I really like the billiard ball clocks. JTTHECLOCKMAN and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted June 19, 2019 Report Share Posted June 19, 2019 14 minutes ago, Rolf said: Jt I really like the billiard ball clocks. Thanks they are big sellers for me. I have a few other ideas I have been wanting to do with them but never got around to it. Quote Link to comment Share on other sites More sharing options...
Rolf Posted June 20, 2019 Report Share Posted June 20, 2019 (edited) Where do you get the billiard balls.? Also the bases you made really do a lot to make them pop. Edited June 20, 2019 by Rolf OCtoolguy and JTTHECLOCKMAN 2 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted June 20, 2019 Report Share Posted June 20, 2019 Thanks again. I made the bases to resemble the Rack sort of. They are rosewood and oak. Being I use lots of them I buy the balls from China. You can get cheap sets on Ebay but many times they have been used. These are not the real good professional ones used in games but they work well. I sell all numbers and let the customer choose. Have to say I sold probably as many 8 ball as 10 ball because the clock face. People love that blue clock face. Have sold many of the cue ball too and people like a black outer ring and white face with that one. The same one that is on the green 6 ball. John B and Dave Monk 2 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted June 20, 2019 Report Share Posted June 20, 2019 Those clocks are stunning! OCtoolguy and JTTHECLOCKMAN 2 Quote Link to comment Share on other sites More sharing options...
teachnlearn Posted June 21, 2019 Report Share Posted June 21, 2019 (edited) 12 hours ago, JTTHECLOCKMAN said: Thanks again. I made the bases to resemble the Rack sort of. They are rosewood and oak. Being I use lots of them I buy the balls from China. You can get cheap sets on Ebay but many times they have been used. These are not the real good professional ones used in games but they work well. I sell all numbers and let the customer choose. Have to say I sold probably as many 8 ball as 10 ball because the clock face. People love that blue clock face. Have sold many of the cue ball too and people like a black outer ring and white face with that one. The same one that is on the green 6 ball. Since your doing clocks on billiard balls add the option of the clock at the back of the cue stick. A continued billiard idea. RJF Edited June 21, 2019 by teachnlearn OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted June 21, 2019 Report Share Posted June 21, 2019 1 hour ago, teachnlearn said: You do have the added option of the clock at the back of the cue stick? RJF Sorry did not follow this. Quote Link to comment Share on other sites More sharing options...
JimErn Posted June 21, 2019 Report Share Posted June 21, 2019 7 hours ago, JTTHECLOCKMAN said: Sorry did not follow this. I am not sure either, the only spot would the the end, but a cue stick has too small a diameter to put a clock on. OCtoolguy and JTTHECLOCKMAN 1 1 Quote Link to comment Share on other sites More sharing options...
