teachnlearn Posted June 21, 2019 Report Posted June 21, 2019 9 hours ago, JimErn said: I am not sure either, the only spot would the the end, but a cue stick has too small a diameter to put a clock on. Watch face would work fine. RJF OCtoolguy 1 Quote
JimErn Posted June 21, 2019 Report Posted June 21, 2019 1 hour ago, teachnlearn said: Watch face would work fine. RJF I guess it depends on the watch face, but the watch/clock inserts talked about here are 1 7/16 diameter, and require a 1 3/8 hole a standard pool cue is 1 1/4 diameter at the hilt OCtoolguy 1 Quote
new2woodwrk Posted June 21, 2019 Report Posted June 21, 2019 On 6/17/2019 at 8:52 AM, JimErn said: it is attached clock-insert-template.svg 13.41 kB · 16 downloads Sweet thanks a bunch OCtoolguy 1 Quote
teachnlearn Posted June 21, 2019 Report Posted June 21, 2019 (edited) 27 minutes ago, JimErn said: I guess it depends on the watch face, but the watch/clock inserts talked about here are 1 7/16 diameter, and require a 1 3/8 hole a standard pool cue is 1 1/4 diameter at the hilt Edited June 21, 2019 by teachnlearn OCtoolguy 1 Quote
teachnlearn Posted June 21, 2019 Report Posted June 21, 2019 30 minutes ago, JimErn said: I guess it depends on the watch face, but the watch/clock inserts talked about here are 1 7/16 diameter, and require a 1 3/8 hole a standard pool cue is 1 1/4 diameter at the hilt Drill counter sink a wooden ball on to the back of the cue and drill the 1 3/8 insert hole. There's a way, There's a way. RJF OCtoolguy 1 Quote
kmmcrafts Posted June 21, 2019 Report Posted June 21, 2019 Just now, teachnlearn said: Drill counter sink a wooden ball on to the back of the cue and drill the 1 3/8 insert hole. There's a way, There's a way. RJF That's what I was thinking ( I think ) You mean to use a cue as sort of a stand? between the base and the pool ball? I almost mentioned that yesterday.. OCtoolguy 1 Quote
OCtoolguy Posted June 21, 2019 Report Posted June 21, 2019 1 hour ago, teachnlearn said: Drill counter sink a wooden ball on to the back of the cue and drill the 1 3/8 insert hole. There's a way, There's a way. RJF That's going to surely throw the balance of the stick off a bit. LOL. kmmcrafts 1 Quote
teachnlearn Posted June 22, 2019 Report Posted June 22, 2019 1 hour ago, octoolguy said: That's going to surely throw the balance of the stick off a bit. LOL. But you can time your shot. RJF OCtoolguy 1 Quote
OCtoolguy Posted June 22, 2019 Report Posted June 22, 2019 41 minutes ago, teachnlearn said: But you can time your shot. RJF How do you aim and shoot and look at the time all at once? Quote
teachnlearn Posted June 22, 2019 Report Posted June 22, 2019 4 minutes ago, octoolguy said: How do you aim and shoot and look at the time all at once? Kind of like a rifle, look down the barrel from behind. RJF OCtoolguy 1 Quote
kmmcrafts Posted June 22, 2019 Report Posted June 22, 2019 21 minutes ago, octoolguy said: How do you aim and shoot and look at the time all at once? Wouldn't the clock still be in the ball? OCtoolguy 1 Quote
kmmcrafts Posted June 22, 2019 Report Posted June 22, 2019 My pool themed clock incorporates the pool table all the balls.. After I made and sold this.. we was at a restaurant and they put those big wood tooth picks in our sandwiches.. I thought about asking if i could buy a few of those ( unused ) to use them on the front and back of the table/ base as the cues.. never did ask though LOL.. OCtoolguy and Rolf 2 Quote
JTTHECLOCKMAN Posted June 22, 2019 Report Posted June 22, 2019 Well I will tell you this and will let anyone who wants to try that idea have at it but it won't be me. But what I will tell you the Clock that Kevin has just shown I will step that design up a few notches at some time. Just have to figure a few things out yet. I put that project on the back burner last year but will revisit it. I also will be making pool cue pens with watch parts embedded into the pen body and adding them to my revolving list of projects. Not sure how many remember this pen box I made a few years ago for a contest I entered on a pen turning site and it happen to take first place. Roq, Rolf, kmmcrafts and 1 other 3 1 Quote
Scrappile Posted June 22, 2019 Report Posted June 22, 2019 @JTTHECLOCKMAN, I remember my days at IAP and I know you will. You do some very amazing stuff. JTTHECLOCKMAN and OCtoolguy 2 Quote
Rolf Posted June 22, 2019 Report Posted June 22, 2019 (edited) NOW that is a cool project! Edited June 22, 2019 by Rolf JTTHECLOCKMAN and OCtoolguy 2 Quote
kmmcrafts Posted June 22, 2019 Report Posted June 22, 2019 Thats awesome JT.. While I like the project I did because it was different and unique to to what others did with the same pattern..I like the little ball clocks better... I don't really like the main pattern / part with the clock I made here.. The thing is... is the clock is ( In my opinion ) lost in the big shape.. I used that size for two reasons.. one being that was what the design called for and two, that was about the size the balls are in the pattern... But I felt like the clock is way to small in that design.. so if you make something with that pattern... change it up somehow to make the clock not be lost in the design.. It's a neat pattern and fun one to cut.. But.. I think it could be improved on quite a lot too.. I'm sure with you're talent and creative ideas you'll do something awesome with it.. OCtoolguy 1 Quote
JTTHECLOCKMAN Posted June 22, 2019 Report Posted June 22, 2019 1 hour ago, kmmcrafts said: Thats awesome JT.. While I like the project I did because it was different and unique to to what others did with the same pattern..I like the little ball clocks better... I don't really like the main pattern / part with the clock I made here.. The thing is... is the clock is ( In my opinion ) lost in the big shape.. I used that size for two reasons.. one being that was what the design called for and two, that was about the size the balls are in the pattern... But I felt like the clock is way to small in that design.. so if you make something with that pattern... change it up somehow to make the clock not be lost in the design.. It's a neat pattern and fun one to cut.. But.. I think it could be improved on quite a lot too.. I'm sure with you're talent and creative ideas you'll do something awesome with it.. Kevin I have a couple different versions in my head. I had seen a similar pattern that I may combine both patterns and add some things. Just not sure yet. As I said I need to work out a few details yet with my method. Right now I am waiting on some supplies for my puzzle project and will be working on that. kmmcrafts and OCtoolguy 2 Quote
