Spent all day yesterday in refresher FirstAid/CPR courses, so I hit the garage for a quick pattern today.  1/2" Plywood (not sure the flavor), cut with a #2 spiral, a quick once-over with a blowtorch to remove the feathers off the back (and to scorch the front, I thought the patterns raised on the back looked cool), then stained with Minwax Cherry stain.  Hung crooked on purpose (mostly to mess with my wife's OCD, plus its a bit 'off' which fits my personality).
3 minutes ago, Foxfold said:
That looks brilliant.  I wish I was good enough or brave enough to try spirals again, but alas, I'd not make something as good as this.
Heh.  If you look closely at it, you can tell there were a lot of spots where the spiral decided to go its own direction and I had to nurse it back on track, or I got momentarily distracted and ate into the lettering a bit (or didn't cut a corner quite as tightly as I should've).  Its a rough-cut piece, and I decided not to file it down because, honestly, I hate filing/sanding.  LOL  That, and it kinda works, with rough edges.
