I just started using pegas  blades and the wear time on 1/4 BB ply is about 1+  hour but on 3/4 pine it is  about I got 20 minuts and they were shot. I had used olson blades for a long time
and the wear time was a lot higher  the same speed. pegas blades are LOT smother running  and I was almost sold on them.
IKE
IKE
What Olsen blades do you run?
I've had just the opposite.. the Pegas last a lot longer than the others I've used.. I will say they don't like heat.. so if you're running a pretty fast saw speed.. they'll dull quicker.. I don't have this issue on my Excalibur.. but I do on the DeWalt and Hawk but these two saws have a faster running speed.. i have to turn it down some for these two saws..
Another thing too.. They do cut straighter than most the other blades.. and when I first tried them I kept pushing sort of more on the side of the blade as I was used to the couple of degrees off that most blades have.. so by doing that I was creating a little more heat with them..
Kevin, I had the exact same experience. But, in reverse. I was used to using Pegas #5 blades and for some unknown reason, I decided to try some FD blades. All of a sudden I couldn't keep them going straight. I had to really push to one side to stay on the line. I love me some PEGAS!
I change it up all the time like that... gives me something challenging to do :) and keeps me in tune with all the different blades..LOL.. I used FD blades for a good 12 + years so I adjust in just a few seconds after switching back from the Pegas.. I do this because I do like to be well versed in being able to use about any blade thrown my way..
I don't reckon I've had a chance to test drive all them fancy blades. I may have to keep some of those names stashed in my thinker box fer a rainy day.🤔
Personally, I ain't never run nothin but Olson &  Flyin Dutchman blades of all sizes and types & ain't never had no issues with them.
The #0 & #1 blades do have a tendency to stray off the cut line, but to solve that issue, I run my blade tension a little tighter than the hot shots say to, & I slow the blade speed down a snort. If'n yer in such a all mighty hurry that you're runnin that blade might near full throttle, ya ain't got any business scrollin.
In all honesty, scroll blades despise heat & speed. The two together will wreck yer blade faster'n ya can change'em! Especially in hardwood. Learn to find a speed that yer saw & blade are workin at an even keel, & constant speed. Regardless of how fancy a name yer blade has, it'll keep cuttin fer a long, steady, even cut.
Learn to be consistent, easy on the throttle, & let the blade do the work. You'll find your results will change, yer blades will keep cuttin, regardless of the breed of blades, wood, or saw.
Sawdust703(brad)
Sawdust703(brad)
All good info Brad. Thanks. Good to see your input.
