Did this Friday night and Saturday morning. Its going in Damien's bar in his house for his retirement pressie (its a surprise so don't tell him). I have to add in a firefighter helmet and something else, and then shape it into a fancy plaque, then back it and stain it.
Its 6mm BB. Did the S in Damien's with a Pegas 5 modified geometry. Face looked good but the back was rough so I changed to a Pegas # 3 reverse skip. Cut about 20 letters, and went off to bed. Next morning cut about 10 letters and then the blade broke. Over the next 2 letters, 3 # 3 blades broke. Changed back to the original # 5 blade and finished it without any problem.
1st # 3 broke because the top slipped from the clamp and the blade bent at the bottom before I could stop the motor, but I don't know why the next 3 broke. It  certainly brings on bad language.
Bob
thumbnail?appId=YMailNorrin
By any chance do you have some of those Pegas blades that had the notch cut in them at the top? There are still thousands of them out there. I had some breakage too but then I learned that if I clamped the blades higher with the notch right under the clamp screw, no more breakage and there was still enough reverse teeth at the bottom that I got a clean underside cut.
