Kepy Posted July 29, 2019 Report Posted July 29, 2019 I was in a Dollar Tree the other day and found some shelf paper that was adhesive. I am working on a 12x12 pattern so thought I would give it a try. Seems to be working fine on a stack of 1/8" BB. I didn't cut it large enough to wrap around the edges to had to tape them together. OCtoolguy 1 Quote
kmmcrafts Posted July 29, 2019 Report Posted July 29, 2019 I've tried wrapping it around the edges and found that it's thicker than packing tape and also seems to not stick quite as good as packing or blue tape.. so I always put the shelf liner on the top piece and then use packing tape to go around each side to hold the stack together.. Seems to work better than the shelf liner for the stack cutting.. OCtoolguy and Roberta Moreton 2 Quote
Roberta Moreton Posted July 29, 2019 Report Posted July 29, 2019 The shelf paper is not tape. OCtoolguy 1 Quote
Gonzo Posted July 31, 2019 Report Posted July 31, 2019 Use a hot glue gun on the edges. OCtoolguy 1 Quote
