rjR Posted August 3, 2019 Report Posted August 3, 2019 Having seen Barb J. Enders very well done double sided tree puzzle gave me the idea to do this! So " Thanks Barb." Meanwhile back to the subject; I have a craft show coming up and a few of the things I make can be put on pegboard for the best display. So I decided that vertical room is free, I might as well make a way to use it. The farm boy was showing through again, and the show has a "rural'" theme and setting-- so do a barn. Lettering and some of the trim cuts are scrollsaw work. Most of the barns that I have ever seen were either red with white trim or white with black trim. Well the Double tree was the inspiration for this. It is 28+ inches tall and 36" wide folded to the open position. The trim is all real wood-1 x 2 cut with a slot for the pegboard insert. The lettering is just plywood 1/4 inch scrap that was lying in the shop. The font was just some rjR and T & E designs again. The piano hinge was tricky and I may even end up changing it after the show, if it does not work the way I want. One picture includes some of the items that I am getting ready for the show. crupiea, amazingkevin, jollyred and 2 others 5 Quote
lawson56 Posted August 4, 2019 Report Posted August 4, 2019 1 COOL Idea.And Very Cleverly done.Looks Awesome!!! Quote
amazingkevin Posted August 6, 2019 Report Posted August 6, 2019 You are so right about vertical space is free. I realized that quick at my first and only show.keep up the great work Ralph,it's all quality time! Quote
