Popular Post Wilson142 Posted August 14, 2019 Popular Post Report Posted August 14, 2019 Not exactly earth shattering but, I was in the middle of a delicate fretwork pattern on my DW788. I was using painters tape to support the cuts and lamenting the good old days (90's) with my little 15 inch Ryobi with its set up for zero clearance inserts. They came in like 3 packs and slid right into the recess under the blade. Then an idea popped up. I remembered I had a business card from a local plumber that was printed on a thin magnetic rectangle on my fridge. It's 4" x 4" and sticks perfectly to my saw table. I know this isn't genius but works like a champ! Thought I'd pass it on. OCtoolguy, meflick, John B and 8 others 6 5 Quote
JTTHECLOCKMAN Posted August 14, 2019 Report Posted August 14, 2019 Good tip thanks for passing on. OCtoolguy 1 Quote
Dee Posted August 15, 2019 Report Posted August 15, 2019 If you go to the local sign shop where they make magnetic signs and ask to check out their scrap box, you can get a piece large enough to cover almost all the table for little or nothing. barb.j.enders, OCtoolguy, new2woodwrk and 1 other 3 1 Quote
new2woodwrk Posted August 15, 2019 Report Posted August 15, 2019 great tips - thanks for sharing them OCtoolguy 1 Quote
crupiea Posted August 15, 2019 Report Posted August 15, 2019 Great tip. I use an old casino playing card that has a hole punched in the middle of it. Pretty much same result. I just happen to have a bunch of them. OCtoolguy 1 Quote
barb.j.enders Posted August 15, 2019 Report Posted August 15, 2019 I too use an old fridge magnet "business" card OCtoolguy 1 Quote
