Scrappile Posted August 19, 2019 Report Posted August 19, 2019 I did something last evening that I know is not going to be excepted here. I don't ask for forgiveness, I'm not proud of it but it had to be done, for now at least. I removed my Pegas clamps from my Seyco saw and went back to the old original clamps!!!!! I know, I know, I may be banned from here but I ask for your understanding. Here is why: I started cutting a picture that is my kind of fun scrolling. Detailed. I have to use Flying Dutchman 3/0 New Spiral Blades to accomplish it. I could not clamp the 3/0 Spiral in the Pegas clamp without getting the "Hockey Stick" bend in each end. I tried every trick I have learned in my years of scrolling to prevent it, but no matter, best I could do was get 3 or so clampings and it would happen. I am convinced it has something to do with the fact there are more exposed threads in the back of the Pegas clamp where you put the blade. The back of the original clamps has a very small area that has exposed threads and they are not as deep. That is the only difference I could see. I suspect the twist of that thin spiral is catching in a thread. I had it happen more often with a 2/0 pegas spiral also than I did with the original clamps. That is my second go to spiral blade. Anyway, I am back to the old clamps, at least when using the 3/0 spiral. Don't know is it is worth changing back to the Pegas clamp when not, I have to think on that..... maybe get a third scroll saw... several nice older Excaliburs for sale with in a couple hundred miles of me......... lawson56, Dave Monk, Phantom Scroller and 2 others 3 1 1 Quote
jbrowning Posted August 19, 2019 Report Posted August 19, 2019 I personally think you should buy another scroll saw. You can never have too many scroll saws. RabidAlien, Scrappile, jerrye and 2 others 2 3 Quote
kmmcrafts Posted August 19, 2019 Report Posted August 19, 2019 I agree with Jim.. But that said.. did your pegas clamps come with the thumb screws that have the swivel end? If I remember correctly mine did not and I swapped out the thumb screws from my DeWalt.. I had a backup set for the DW so i used the new set of the swivel thumb screws.. I also had some issues with the thumb screws that came with my Pegas clamp.. but not sure now what I had issues with other than I remember the knobs on the Pegas clamps was bigger and smooth.. and I liked the smaller style that I had for my DW.. so I swapped them.. jbrowning and OCtoolguy 2 Quote
OCtoolguy Posted August 19, 2019 Report Posted August 19, 2019 Paul, if I'm understanding correctly, I ask if you have the clamp screw anvils adjusted so that they protrude just a tiny bit proud of the wall of the clamp jaw. The only reason that I can think of for the blade ends to bend is if they are being forced into a recess when tightened. I have mine adjust so that the blades are captured between the opposing faces of the clamp screw and its anvil face and no contact with anything else except the rear wall of the clamp housing. With that in mind, the only reason for the hockey stick bend might be that the clamp screw and anvil faces aren't flat or parallel. Also make sure the tip of the clamp screw is swiveling correctly. Take it out and lube it once in a while. SCROLLSAW703 1 Quote
Scrappile Posted August 19, 2019 Author Report Posted August 19, 2019 I have made all kinds of the know adjustments, cleaned all kinds of parts, cleaned blades, untwisted the ends of the blade with no improvement. I even thought of bad blades, but switched clamps and no problem so far. Keep in mind, this is a very thin flexible blade compared to all the other blades I use. I have not had this problem with any other size blades I use, well a few times with the Pegas 2/0 spiral, but I expect it to happen more often with a spiral blade than a flat blade... Maybe I will play with it more some day when I an trying to not make pictures frames that I need to be making... OCtoolguy 1 Quote
Scrappile Posted August 19, 2019 Author Report Posted August 19, 2019 @kmmcrafts, yes they have the swivel end, which I cleaned well. OCtoolguy and kmmcrafts 2 Quote
Wilson142 Posted August 19, 2019 Report Posted August 19, 2019 Good info. I was contemplating the Pegas clamps for my Dewalt but maybe I'll wait. Pegas 2/0 and 3/0 are my go to blades also. I've been top loading lately and find I hockey stick my lower end more than when I bottom load. OCtoolguy 1 Quote
Scrappile Posted August 19, 2019 Author Report Posted August 19, 2019 @Wilson142, help a guy out, buy some, use them and see if you have the same problem with the 3/0 Spiral.....Then let me know, they are only $100..... OCtoolguy 1 Quote
Wilson142 Posted August 19, 2019 Report Posted August 19, 2019 My bearings seem a bit sloppy in the chuck heads, so I ordered a set. Actually they were $64.00 except I fat fingered the shipping selection and hit the UPS 3 day for an additional $11. oops! We'll see what happens. I hope they work, I have a gross of 2/0 Pegas and 3/0 FD. I also tried some #0 and #1 blades and may buy a gross of them also. OCtoolguy 1 Quote
Scrappile Posted August 19, 2019 Author Report Posted August 19, 2019 @Wilson142, That's right the DeWalt set is a little cheaper. No Tension lever on the top clamp. I will be anxious to read your take on them. OCtoolguy 1 Quote
Jim McDonald Posted August 20, 2019 Report Posted August 20, 2019 @Wilson142, I put a set on my Dewalt and have not had a minute of problem. That said, I don't use blades that small. OCtoolguy 1 Quote
Wilson142 Posted August 20, 2019 Report Posted August 20, 2019 9 hours ago, Jim McDonald said: @Wilson142, I put a set on my Dewalt and have not had a minute of problem. That said, I don't use blades that small. I'm optimistic. I wonder if I should have bought the set with the tensioning lever, although the set without should be a tiny bit lighter. Mike OCtoolguy 1 Quote
scrollingforsanity Posted August 20, 2019 Report Posted August 20, 2019 I need to buy some small spiral blades and try them on my saw Paul. Next time I order I will get some. We can compare that way and see if it's the small blades or the chuck heads, or maybe both. grizz OCtoolguy 1 Quote
Scrappile Posted August 20, 2019 Author Report Posted August 20, 2019 @scrollingforsanity, Next time you are over here, stop by I will give you some.... OCtoolguy 1 Quote
scrollingforsanity Posted August 21, 2019 Report Posted August 21, 2019 Okay Paul. Leaving tomorrow for a week then I will try to swing by. grizz OCtoolguy 1 Quote
Wilson142 Posted August 26, 2019 Report Posted August 26, 2019 On 8/19/2019 at 1:27 PM, Scrappile said: @Wilson142, help a guy out, buy some, use them and see if you have the same problem with the 3/0 Spiral.....Then let me know, they are only $100..... Received my clamps and got them installed after chasing out the threads on one of them. Slightly funky threads but got it sorted. After about 4 hrs cutting 1/4 BB with 3/0 FD New spiral blades, no hockey sticks on either end. They do seem to reduce vibration a bit and the lower clamp is a little easier to blind tighten when top feeding. I used a washer as a spacer to ensure the set screws protrude an equal amount and lubed the bearings well. Good luck. OCtoolguy 1 Quote
Scrappile Posted August 26, 2019 Author Report Posted August 26, 2019 9 minutes ago, Wilson142 said: I used a washer as a spacer to ensure the set screws protrude an equal amount and lubed the bearings well. Good luck. Not sure I understand this, you used a washer just as a gauge or did you put it on somewhere? So hummm, you are sorta telling me it is probably my problem..... I did adjust the screw while I had the clamps off and could see them better. But I did not use any type gauge, I eye-balled it. I put the clamps back on and there is some improvement, still getting hockey stick on the bottom clamp but not as often. Maybe this evening I take them off again and use a gauge to make sure they are both protruding the same. Not sure how far is correct... OCtoolguy 1 Quote
JimErn Posted August 26, 2019 Report Posted August 26, 2019 51 minutes ago, Scrappile said: Not sure how far is correct... Does not matter, as long as the bottom and top set screw are protruding the same amount, then the blade will be plumb, which is what you want I used s set of those old finger type feeler gauges we use to set points back in the day SCROLLSAW703, OCtoolguy and Scrappile 2 1 Quote
OCtoolguy Posted August 26, 2019 Report Posted August 26, 2019 1 hour ago, Scrappile said: Not sure I understand this, you used a washer just as a gauge or did you put it on somewhere? So hummm, you are sorta telling me it is probably my problem..... I did adjust the screw while I had the clamps off and could see them better. But I did not use any type gauge, I eye-balled it. I put the clamps back on and there is some improvement, still getting hockey stick on the bottom clamp but not as often. Maybe this evening I take them off again and use a gauge to make sure they are both protruding the same. Not sure how far is correct... Paul, there is no "correct" amount. Back off both of the clamp screws, stick a thick washer in the slot and tighten the anvil screw up to it until you can just slip the washer back out. Lock the anvil screw down. Do this for both top and bottom clamps. Now, your blades will be in perfect alignment top to bottom. The important thing is that the anvil screws protrude from the clamp body and the same amount top and bottom. Clear as mud? Scrappile 1 Quote
Scrappile Posted August 27, 2019 Author Report Posted August 27, 2019 Took the Pegas clamps off again, set the screws using a feeler gauge, they are both set proud the same distance. Put them back on the Seyco, clamped in new New Spiral 3/0 Flying Dutchman blade, scroll three pieces out and this it the blade.... OCtoolguy 1 Quote
Wilson142 Posted August 27, 2019 Report Posted August 27, 2019 "So hummm, you' are sorta telling me it is probably my problem." LOL, no I'm telling you I didn't have that happen to me. I have know idea why it's happening to you. When I received my clamps, the set screws were turned all the way in, so I found a washer that was approximately half the thickness of the slot and turned the set in to the washer and locked it down. Just like octoolguy posted. I refrain from talking as if I'm any kind of expert and you'll not see me post many absolutes as if I were. I only offer my opinions based on my experiences. I am very much annoyed with self proclaimed "experts", I prefer to think everyone who scrolls for any length of time will develop the techniques that work best for them. l OCtoolguy and SCROLLSAW703 2 Quote
Wilson142 Posted August 27, 2019 Report Posted August 27, 2019 I'm assuming the blade ends have been straightened. Can you feel the blade bending as you tighten the thumb screw? OCtoolguy 1 Quote
Scrappile Posted August 27, 2019 Author Report Posted August 27, 2019 Sometimes yes. I have never had to straighten the ends of spiral blade and sure once in a while I would get hockey stick, but I could also get one once in a great while with a flat blade. I don't know for sure what is happening. I'll keep playing with it. See if I can figure something out. Or not.... OCtoolguy 1 Quote
SCROLLSAW703 Posted August 27, 2019 Report Posted August 27, 2019 Under experienced circumstance, with manufacturers blade assembly, when yer gettin the "hockey stick" result at the blade holder, it's caused from over tightenin of the thumb screw agin the blade. In my experience at the saw, if'n ya run yer thumb screw over a piece of 180 grit sandpaper to run the smooth spots off'n the end of it, over tightenin them smaller blades ain't necessary. Ya should be able to hold yer blades in place with dandy tension. With my techniques, I ain't havin' any issues with my Hawk or CW - 40. Quote
OCtoolguy Posted August 27, 2019 Report Posted August 27, 2019 I was wondering about something. Are the ends bending or are they being "twisted" as the clamp screws are being tightened? Could it be that the clamp screws are not flat and parallel to the faces of the anvil screws? If I were you, I'd get on the phone with Pegas and have a talk. You might have a defective set of clamp screws or clamps. Something doesn't make sense. jerrye 1 Quote
