rustynail Posted August 27, 2019 Report Posted August 27, 2019 12 hours ago, octoolguy said: If I were you, I'd get on the phone with Pegas and have a talk. You might have a defective set of clamp screws or clamps. Something doesn't make sense. Plus #1 can't hurt to call them OCtoolguy 1 Quote
scrollingforsanity Posted August 27, 2019 Report Posted August 27, 2019 Paul, I am no expert but I believe Ray has the right idea. I believe it is the ends on your thumb screws. They are not turning correctly and are bending your blades. f I get over that way I will bring you a new set to try. I am waxing my fifth wheel right now so it might be a while. The thumb screw ends I received with my Pegas clamps were bad. A new set fixed the problem. Or I could wait until you get frustrated enough with them to sell them to me for cheap. Ha! Ha! Just kidding grizz OCtoolguy 1 Quote
Norm Fengstad Posted August 28, 2019 Report Posted August 28, 2019 I have a Seyco, purchased in May. The tension adjustment knob at the back of the saw will back off during cutting and the blade tension will be reduced . when this happens hockey stick distortion occurs sometimes. I find this very frustrating. OCtoolguy 1 Quote
OCtoolguy Posted August 28, 2019 Report Posted August 28, 2019 1 minute ago, Norm Fengstad said: I have a Seyco, purchased in May. The tension adjustment knob at the back of the saw will back off during cutting and the blade tension will be reduced . when this happens hockey stick distortion occurs sometimes. I find this very frustrating. Norm, try the rubber band trick on that knob to keep it from turning. Quote
Scrappile Posted August 28, 2019 Author Report Posted August 28, 2019 (edited) 22 hours ago, scrollingforsanity said: Paul, I am no expert but I believe Ray has the right idea. I believe it is the ends on your thumb screws. They are not turning correctly and are bending your blades. f I get over that way I will bring you a new set to try. I am waxing my fifth wheel right now so it might be a while. The thumb screw ends I received with my Pegas clamps were bad. A new set fixed the problem. Or I could wait until you get frustrated enough with them to sell them to me for cheap. Ha! Ha! Just kidding grizz The ends of both the thumb screw and the the other screw look pretty rough to me. I have been going to make a little jug to sand both. Waxing the fifth wheel. That is a lot of work... I'd help you b-u-t..... that is a lot of work......!! I meant to say make a little "Jig" not jug.... you can see where my mind goes!! Edited August 28, 2019 by Scrappile OCtoolguy and kmmcrafts 2 Quote
kmmcrafts Posted August 28, 2019 Report Posted August 28, 2019 21 hours ago, Norm Fengstad said: I have a Seyco, purchased in May. The tension adjustment knob at the back of the saw will back off during cutting and the blade tension will be reduced . when this happens hockey stick distortion occurs sometimes. I find this very frustrating. Either the rubber band trick or do as I did and take it apart.. put a little blue loc-tite on the threads and re-assemble everything.. Mine hasn't moved since then.. except when I purposely move it... OCtoolguy and SCROLLSAW703 2 Quote
