RabidAlien Posted August 25, 2019 Report Posted August 25, 2019 Put this one together for my daughter. 2x4 ripped in half, I believe, used a Pegas #5mg. Stained with Minwax Provincial. MTCowpoke22, frankorona, Phantom Scroller and 6 others 9 Quote
Phantom Scroller Posted August 25, 2019 Report Posted August 25, 2019 Good cut looks great. Roly RabidAlien 1 Quote
Rockytime Posted August 25, 2019 Report Posted August 25, 2019 That came out great. Did you make your own pattern? Good job. RabidAlien 1 Quote
RabidAlien Posted August 26, 2019 Author Report Posted August 26, 2019 54 minutes ago, Rockytime said: That came out great. Did you make your own pattern? Good job. Yep! I've used Publisher to make this type before, but it was a pain getting the dimensions right. Used Inkscape this time, and just dragged two horizontal guides down, spaced em an inch and a half apart, drew a rectangle, then added text. Resized the text to fit into the rectangles. Sooooooooooooooo much easier than Publisher! kmmcrafts and Rockytime 1 1 Quote
spirithorse Posted August 26, 2019 Report Posted August 26, 2019 Nicely done! Those look like some pretty narrow edges but, you did a fine job of cutting it out! Thanks for sharing and God Bless! Spirithorse RabidAlien 1 Quote
wombatie Posted August 26, 2019 Report Posted August 26, 2019 The boy next door is named Kaylen and he is the only one I have ever heard of and now you have cut the name, so he is not a one off, like assumed. Great work once again. Marg RabidAlien 1 Quote
kmmcrafts Posted August 26, 2019 Report Posted August 26, 2019 Wow that is cool.. I have yet to cut this type of works.. Maybe one day I'll give it a go.. RabidAlien 1 Quote
RabidAlien Posted August 26, 2019 Author Report Posted August 26, 2019 8 hours ago, spirithorse said: Nicely done! Those look like some pretty narrow edges but, you did a fine job of cutting it out! Thanks for sharing and God Bless! Spirithorse Yep, I noticed that after I'd attached the pattern to the wood. Next time I'll beef up the boundary edge a bit. Quote
amazingkevin Posted August 31, 2019 Report Posted August 31, 2019 I've next to no experience in staining but it looks like you got it down pat!!! RabidAlien 1 Quote
