I completed my Eagle picture and I noticed Amazing Kevin cut it also and I was very impressed with what you did . Here is my go at it and this one is mine and going on my wall right beside one I cut out of Oges. I would like to note that i did make a change to the pattern right before I started cutting it . Toolbeltman mentioned the beak did not have enough detail so the only thing I changed was I put a cut at the forehead and back of the beak to seperate the two. I think it was just enough to give it that detail it needed . I cut it out of 1/8 in. Baltic Birchply and it is 12 by 14 and I decided to make a Rough Sawn Cedar frame for it . I also posted the picture I made the pattern off of . I would like some feed back , Thanks Eagledrum70 :)
