don watson Posted August 29, 2019 Report Posted August 29, 2019 Hi All, I had to start a new thread as I was using too much of the thread where this started. I have found a sample to be cut to test if you would like to try wooden gear clock making. It can be found on the Brian Law site at www.woodenclocks.co.uk and is an ideal way to find if you have the patience/aptitude and skills you will need. I will try and post it here but it might not work. take care Don W sample_1.dxf OCtoolguy and lawson56 1 1 Quote
OCtoolguy Posted August 29, 2019 Report Posted August 29, 2019 (edited) 2 hours ago, don watson said: Hi All, I had to start a new thread as I was using too much of the thread where this started. I have found a sample to be cut to test if you would like to try wooden gear clock making. It can be found on the Brian Law site at www.woodenclocks.co.uk and is an ideal way to find if you have the patience/aptitude and skills you will need. I will try and post it here but it might not work. take care Don W sample_1.dxf 174.31 kB · 5 downloads Don, I can't get that to open. I have Irfanview but I don't have that CAD add-in. Can you help? Edit: Never mind Don, I figured it out. Thanks. Edited August 29, 2019 by octoolguy Quote
Rockytime Posted August 29, 2019 Report Posted August 29, 2019 Don, you use Delta Cad? I have had it for years and have since forgotten how to use it. Didn't know it still existed. Nice to know. OCtoolguy 1 Quote
Scrappile Posted August 30, 2019 Report Posted August 30, 2019 (edited) Thanks for starting a new thread on this subject. This should be interesting, least I hope it is. I have always admired the wooden geared clocks. I have one started, actually all the parts cut out and started assembly around two years ago. Something was not right about my assembly and I decided to set it aside for a little while. Well it has been longer than a little while. Mine is the Ascent from this site: https://wooden-gear-clocks.com/ The plans are very well done and the seller is very nice to work with. Another great place for patterns is here: http://lisaboyer.com/Claytonsite/Claytonsite1.htm The plans from here are awesome also. I have done the three robots from his "Robot Laboratory" and have the plans for doing the Puffer Steam Engine. The robots were very fun to build, they all worked and fun to play with. The first picture below is what my clock is suppose to look like, if and when..... The second picture is my clock partially assemblied. I made a couple cosmetic changes to mine... should not affect the way it work....if it ever works. I even have the numbers cut and ready to glue on the dial ,,,,, Edited October 20, 2019 by Scrappile OCtoolguy, RabidAlien and Be_O_Be 2 1 Quote
Sycamore67 Posted August 30, 2019 Report Posted August 30, 2019 Hopefully, Rolf will post his thoughts as he has made a few and written articles about them. Quote
don watson Posted August 30, 2019 Author Report Posted August 30, 2019 @octoolguy, Hi Ray, glad you got that to open, I posted here as a .dxf and I have a .dwg file that I am trying to open with the Librecad (when I figure how that works). Can you print out the pattern at the right size for cutting ?? It is a simple 2 gears attached to a piece of wood and if sized and cut correctly is a very pleasing project.Good luck with it. We are trying the Genesis clock from the book and have cut a couple of gears from ply, The ply was NOT Baltic Birch plywood and it shows in the finished gears, this is why we are determined to get the correct plywood. I will attach a couple of pics. @Rockytime, Hi Les, I normally use/d DraftSight but they are no longer supporting the free version after the end of December 2019. I have downloaded and installed LibreCad and I am trying to use it for my CAD drawings. It's not much different but at 80 years of age it is another challenge along the way. LOL @Scrappile, Hi Paul, Your clock is looking very good. I believe you are allowed cosmetic changes, faces, hands etc. and these can be quite personal, it is the actual gear sizes and pitches between them that need to be quite accurate to get the clock to run. You have made a very good start with the Ascent and Jeff has a really good business going with the full range of goodies from bare drawings up to the full laser cut ready to assemble kits. Clayton Boyer on the other you site mention has a clock in the book we are using and it is the Genesis, the clock we have picked to build. take care Don W OCtoolguy 1 Quote
OCtoolguy Posted August 30, 2019 Report Posted August 30, 2019 Don, I see from your pic why it's imperative to use the best quality of plywood. It would be a heartbreaker to do all that careful cutting and then find those voids. I will start gathering the best wood I can find and begin my mental buildup. Right now I'm battling a finish problem. That is my weak spot. don watson 1 Quote
don watson Posted August 31, 2019 Author Report Posted August 31, 2019 Ray, it was the cheapest quote and this was the result. We have been quoted a new set of prices from our joiner (who gets the trade price) and will be ordering next week. The new ply is guaranteed BB/B (whatever?), it will have a flawless front face and may have some butterflies in the other face. We may need to order a couple of sheets of the 6mm as the scroll saw group and the Pyrography group would like to use it. OCtoolguy 1 Quote
Gonzo Posted August 31, 2019 Report Posted August 31, 2019 I also made the Ascent clock. It was a fun project to make. Unfortunately, I can't get it to run. Just a tad bit disappointed, but it's neat piece of art. Made mine out of BB plywood. I highly recommend making one. OCtoolguy and don watson 1 1 Quote
loftyhermes Posted August 31, 2019 Report Posted August 31, 2019 39 minutes ago, don watson said: Ray, it was the cheapest quote and this was the result. We have been quoted a new set of prices from our joiner (who gets the trade price) and will be ordering next week. The new ply is guaranteed BB/B (whatever?), it will have a flawless front face and may have some butterflies in the other face. We may need to order a couple of sheets of the 6mm as the scroll saw group and the Pyrography group would like to use it. Hi Don, I buy all my ply from SLEC, I don't know how they'll compare with your supplier but worth having a choice. https://www.slecuk.com/ply/birch-ply/60mm-14quot-birch-bbbb?limit=25 OCtoolguy and don watson 1 1 Quote
don watson Posted September 2, 2019 Author Report Posted September 2, 2019 Thanks for that Steve, I will check with my joiner friend and see if he can get a quote. Don W OCtoolguy 1 Quote
don watson Posted September 3, 2019 Author Report Posted September 3, 2019 A quick visit to the 'Shed' today and there is one chap attempting the electronic clock (doing well with it), I have attached 2 pics OCtoolguy and meflick 1 1 Quote
don watson Posted October 20, 2019 Author Report Posted October 20, 2019 The last visit to the shed showed this result. Seems to be coming along nicely. OCtoolguy and Scrappile 1 1 Quote
heppnerguy Posted October 22, 2019 Report Posted October 22, 2019 I cut the same one that Paul (Scrappile) is trying to complete. I could not get mine to run either but I do still have the plans and I really like the wooden clocks. May give it another try, some day. Dick heppnerguy OCtoolguy 1 Quote
don watson Posted November 4, 2019 Author Report Posted November 4, 2019 At last the clock is finished. It is being fine tuned with the Oscilloscope and keeps good time. Now on to another page in the book. lol Don W OCtoolguy and Be_O_Be 1 1 Quote
Sycamore67 Posted November 4, 2019 Report Posted November 4, 2019 Very well done! OCtoolguy and don watson 2 Quote
Be_O_Be Posted November 4, 2019 Report Posted November 4, 2019 Looks great. Are you making the hands? OCtoolguy and don watson 2 Quote
hineps Posted November 4, 2019 Report Posted November 4, 2019 Did you make the electronics or purchase them? If purchased could you provide your source? Phil OCtoolguy and don watson 2 Quote
don watson Posted November 5, 2019 Author Report Posted November 5, 2019 The hands are being made by the Scroll Saw Squad, I hope to see the clock finished next week. The electronics were bought from an American firm and there was all sorts of taxes etc to pay to get them released from the Post Office. I will post full details here when I have had a word with the quartermaster who oversaw the purchase of parts. OCtoolguy 1 Quote
