I ordered new blade holders for my WEN 3921 the other day. They came in yesterday and I tried them today. Very nice!! They eliminate the micky mouse adapters that came with it. Although I haven't looked at the blade holders, I think it works more like the better saws that are pinless only. They are still capable of using pinned blades.
I used  those same adapters on my Wen and was quite content. Only reason I upgraded when I did was that some bushing or bearing finally crapped out and vibration made the saw impossible to work with. I figured the cost of trying to fix wasn't worth it. I got 18 months out of the Wen. Moved up to a Delta and happily making sawdust.
6 hours ago, new2woodwrk said:
Where did you get those? I have a wen as well as a delta but would like to be able to use both for different projects - looks like those would help to use the same blades on both machines
https://wenproducts.com/collections/parts/products/upper-lower-blade-holder
I forgot to order the 2 of the Allen head screws M4x16. So I just grabbed a couple of hex head bolts for now (they are silver in the pictures). I'll change so I can use a T handle Allen wrench or find a metric nut driver and keep these.
Scrappile has a good idea about one with a knob end! I'll look into that. Thanks for the idea Scrappile !
Edited by OzarkSawdust
8 hours ago, Dennisfm56 said:
I found a longer screw that I could use and then used wingnuts to loosen the clamp.
The pinless adapters that came with it used wing nuts. I didn't even check to see if they are the same size, I'll do that today.
* I checked and the wing nuts in the furnished adapters are too short.
