Usually it is done by cutting a rebate in the edge of the wood, deeper than the glass.  Glazier's points are then driven in to hold the glass in place, then a retaining strip is put in to help hold the glass in and cover the points.  If it is in a window, putty is used instead of the strips to waterproof the joint.  In picture frames, a back cover is placed over the points to protect the picture.  If the glass is ever broken, the glazier's points are easily removed so the glass can be replaced.  The process is known as glazing, and there are probably a lot of Utube videos on it.
16 hours ago, dgman said:
E6000. It comes in a tube and adheres anything to anything. You can find it at any craft store and most hardware stores. It’s a clear gel and flex’s if necessary. I use it to mount D hangers to projects. Have never had a failure.
Thanks I will give E6000 a try.
