i need some help, i bought this pattern from pedro of finescrollsaw.com, and the pattern is for 1/8 wood, i will be using 1/4 inch wood, how do i scale the pattern to fit 1/4 ich wood (birch) its the windmill clock pattern, i have a kodak printer, if neone knows what % to scale it, would be great, thanks in advance
Jim
Would you rescale the whole pattern?
1/4 is twice as large as 1/8
But if you rescale it that much the whole thing will be twice a big
Couldnt you just go through each pattern piece that connects to each other and hand change from 1/8 to 1/4
Maybe im thinking of this wrong
Dale, yeah the pattern said it is made for 1/8 wood, and the way some of the pattern is has that other pieces go into each other, hard to explain, but all i did is made them wider by 1/8 so 1/4 would fit in them. sorry if that dont make sense, but it is hard to explain, thanks
I don't worry about the thickness. I would draw it up and cut it except for the notches, leave them until last. Hold all the bits together and you will see what , if any, adjustment is needed. Re-sketch the new positions and cut them. Magic
