 Just moved to a new house and have setup my saws in a pre built shed with a plywood floor that came with the house we bought. Before I always had them setup on a cement floor. Being in the shed I have terrible vibration when I have 2 saws going. Saws are cutting fine and no problems.
Was wondering if putting a rubber mat under them would help it. I see Tractor supply sells those heavy rubber stall mats and was thinking of using one of those under the saws?
Any other thoughts?
How about putting down another layer of plywood to "stiffen" the floor. Or maybe try to find a piece of 1 inch plywood to put under your saws and screw it to the existing floor. You've got to take the spring out of the floor. I have the same problem in my shed. I have my saws sitting next to the walls to get as much firm support as possible and I also put the rubber matting down. Solved most of the problem.
