42 minutes ago, Rockytime said:
That's just Fein (pun intended) if you have one. I thought you had a Duststopper. Was it not you that told me about the Duststopper?
Les, I have two systems. I have the Fein/Dust Deputy for my scroll saws inside my shop. Outside, I have the one that I posted the video on with the H/D shop vac and Dustopper combo. I use my table saw, drum sander etc outside on my driveway so that's where I use the one that you are talking about.
18 hours ago, kmmcrafts said:
Metrovac kept bouncing around in my head today, 'Yep, soft head' and it occurred to me car detailers use that brand to blow dry cars that have been washed. RJf
Various Models:
https://smile.amazon.com/stores/node/19084358011?_encoding=UTF8&field-lbr_brands_browse-bin=METROVAC&ref_=bl_dp_s_web_19084358011
Well just doing a quick search online for Seycos model number for the vac.. and I found these.. not all that cheap and it's different from the photos above.. The photo Denny posted it shows like a filter or muffler type thing on the opposite end from the suction hose.. I'm assuming that is sort of a muffler thing if these are the same.. as this one is much louder than the one Seyco sells.. Seyco list it being 62db noise level and the one from the link below shows 75db
https://www.grainger.com/product/9TF54?gclid=CjwKCAjw29vsBRAuEiwA9s-0Bw1jD77P62NvTYrLi2tlUjWAL5i8dakg2Y2XB61WBcvmTYeMSh2LCBoCK4IQAvD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=CjwKCAjw29vsBRAuEiwA9s-0Bw1jD77P62NvTYrLi2tlUjWAL5i8dakg2Y2XB61WBcvmTYeMSh2LCBoCK4IQAvD_BwE:G:s&s_kwcid=AL!2966!3!281698275117!!!g!472467987775!
Also a couple of them used on eBay for around the $50 mark
On 9/25/2019 at 7:33 PM, Rockytime said:
Kinda pricey for sure. I had a Dust Deputy but it was very tippy and clumsy so I gave it away. I recently purchased a DustStopper from Home Depot for $40. Pick up at store and hooked up to an old Filter Queen vacuum. Sits on a 5 gallon bucket. Very cheap and inexpensive. The vacuum runs constantly. Since the picture the extra long hose on the vacuum has been shortened and it all tucks out of the way under the small table.
Les, what model Filter Queen is it that you are using. I'm curious. There a many on eBay for sale. One new one still in box for only $1200. But there is another one for $25. Lots to choose from. It might be nice to know which one you are using.
I have two, an old one and an even older one and they both perform the same. They do run very strong. Mine runs continuously while scrolling and the total decibels with the vacuum, box fan and saw running remains about 65 dB..
  • 4 weeks later...
