So this is my first time stack cutting. 3 pcs of 1/8 bb ply. Tried it with a simple pattern. First time using something other than a 2/0 blade. Ended up using a FD ur 1. Was surprised how clean the cuts were. Virtually no fuzzies. The backer was 3 pcs of 1/4 bb. The fd ur 1 wasn’t cutting it so I went to a fd ur3 which worked well.
Some things I learned were that a number 3 blade has no problem cutting through your finger tip and through a fingernail. Make the backers a little larger so you have some room to work with. Requires a lot more finishing time. Didn’t like using packing tape. They turned out ok.
Steve Good Pattern.
