OzarkSawdust Posted October 4, 2019 Report Posted October 4, 2019 SO.....to make a smaller hole that doesn't show, or is easier to hide, you use a "numbered" bit. I ordered a pack of 56,60,65,68 which should work for #7, #5, #3, #1 respectively. Other than a micro bit adapter for a drill press, that I don't have, how do you use these tiny things? OCtoolguy 1 Quote
Rockytime Posted October 4, 2019 Report Posted October 4, 2019 Get the Dremel plunge router kit and a Wen or Dremel tool with an adjustable chuck. Seems a good number of scrollers her use it including me. OCtoolguy and OzarkSawdust 2 Quote
teachnlearn Posted October 4, 2019 Report Posted October 4, 2019 Be careful on chucking those up long out of the chuck. They are so thin, its easy to break. RJF OCtoolguy and OzarkSawdust 1 1 Quote
OzarkSawdust Posted October 4, 2019 Author Report Posted October 4, 2019 9 minutes ago, Rockytime said: Get the Dremel plunge router kit and a Wen or Dremel tool with an adjustable chuck. Seems a good number of scrollers her use it including me. Thanks Les! I don't have the adjustable chuck, been using the collets with 1/8th drill bit. I have the Dremel plunge setup, that works good. I'll order the adjustable chuck. OCtoolguy 1 Quote
jerrye Posted October 4, 2019 Report Posted October 4, 2019 (edited) For Wen tool: https://www.amazon.com/gp/product/B072LXHBHP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 For Dremel tool: https://www.amazon.com/gp/product/B0000302ZV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Unless you're anti-Amazon, of course... Edited October 4, 2019 by jerrye OzarkSawdust and OCtoolguy 2 Quote
Dee Posted October 4, 2019 Report Posted October 4, 2019 I have used these tiny bits (as small as a 72 ) for years in the jewelry business. One thing to remember is to NOT push too hard when drilling a hole. Make sure the bit is going in straight and not at an angle and it needs to be clear of any shavings that may stick in the bit. I use mine in both a drill press and a hand drill. When ordering replacements, check with a jewelry supply store. Sometimes you can get them at a more reasonable price. OCtoolguy and OzarkSawdust 2 Quote
Hermit Posted October 4, 2019 Report Posted October 4, 2019 I tried the chuck from Rockler and found it to be worthless. I have a benchtop drill press that takes a number 61 bit with no problems. OCtoolguy and OzarkSawdust 2 Quote
kmmcrafts Posted October 4, 2019 Report Posted October 4, 2019 Over the years I've bought most my small bits from Mikesworkshop But the last time I thought since I was ordering Pegas blades instead of FD that I'd just buy the bits from DnD.. I don't know the brands they both sell but those bits from DnD are a lot better quality than the ones Mikes sells.. so from now on I suppose I'll also switch where I get my bits from.. OCtoolguy, OzarkSawdust and Scrappile 3 Quote
stoney Posted October 4, 2019 Report Posted October 4, 2019 My advice is buy the Dremel chuck from a local retailer not Amazon. I had to return 2 of them that were cheap china knockoffs in a non sealed Dremel package. The one I bought at Lowes was made in West Germany and in a sealed package. OzarkSawdust, kmmcrafts, jerrye and 1 other 2 2 Quote
OzarkSawdust Posted October 4, 2019 Author Report Posted October 4, 2019 5 minutes ago, stoney said: My advice is buy the Dremel chuck from a local retailer not Amazon. I had to return 2 of them that were cheap china knockoffs in a non sealed Dremel package. The one I bought at Lowes was made in West Germany and in a sealed package. I ordered one from Amazon last night. I looked for one at Lowes once, then forgot to hunt further, they didn't have one. At the time I thought it was just a convenience thing. We'll see what happens. If junk I'll order from Dremel to be sure I get the real thing. Thanks for the heads up. OCtoolguy 1 Quote
OzarkSawdust Posted October 4, 2019 Author Report Posted October 4, 2019 21 minutes ago, kmmcrafts said: Over the years I've bought most my small bits from Mikesworkshop But the last time I thought since I was ordering Pegas blades instead of FD that I'd just buy the bits from DnD.. I don't know the brands they both sell but those bits from DnD are a lot better quality than the ones Mikes sells.. so from now on I suppose I'll also switch where I get my bits from.. Not familiar with "DnD" …? OCtoolguy 1 Quote
kmmcrafts Posted October 4, 2019 Report Posted October 4, 2019 (edited) 8 minutes ago, OzarkSawdust said: Not familiar with "DnD" …? https://www.dndsawbladesonline.com/ Their bits also come in little storage tubes too.. Mikes just come in the zip lock bag.. Not that it's a big deal.. but... LOL.. Edited October 4, 2019 by kmmcrafts OCtoolguy and OzarkSawdust 2 Quote
Rolf Posted October 4, 2019 Report Posted October 4, 2019 I find a standard drill press doesn't spin fast enough for the tiny bits. The Dremel Chuck is cheap and works great, I gave up on collets years ago. I use a Micromark drill press for my tiny bits and buy them from amazon. For drilling wood I am not that critical. OzarkSawdust and OCtoolguy 1 1 Quote
crupiea Posted October 4, 2019 Report Posted October 4, 2019 (edited) I use a jewelers twist drill, the screw type. I trim the length of the blade so it barely goes all the way through the wood. Otherwise they will snap under their own weight just about. My go to bit is a #72 so its pretty tiny. Edited October 4, 2019 by crupiea OCtoolguy and OzarkSawdust 2 Quote
Scrappile Posted October 4, 2019 Report Posted October 4, 2019 +1 on DnD 's drill bits. My drill press handles them all. OCtoolguy and OzarkSawdust 2 Quote
