Tammi201 Posted October 13, 2019 Report Posted October 13, 2019 I’m cutting 1/2” and getting a lot of chattering like I have no control and I’m holding on really tight. My hand is hurting. I cutting Hickory and it says it is a soft wood. Maybe I’m just weak. Any ideas? OCtoolguy 1 Quote
dgman Posted October 13, 2019 Report Posted October 13, 2019 Hickory is an extremely hard wood. What blade are you using? If you are using a reverse tooth blade, I would change to a skip tooth blade. Also try experimenting with different size blades. OCtoolguy 1 Quote
kmmcrafts Posted October 13, 2019 Report Posted October 13, 2019 Make sure the blade isn't upside down too.. Don't ask how I know that one.. Jim McDonald, Wilson142, meflick and 4 others 4 3 Quote
Tammi201 Posted October 13, 2019 Author Report Posted October 13, 2019 1 hour ago, dgman said: Hickory is an extremely hard wood. What blade are you using? If you are using a reverse tooth blade, I would change to a skip tooth blade. Also try experimenting with different size blades. I found out it’s hard that is for sure. OCtoolguy 1 Quote
Tammi201 Posted October 13, 2019 Author Report Posted October 13, 2019 56 minutes ago, kmmcrafts said: Make sure the blade isn't upside down too.. Don't ask how I know that one.. I thought of that and took a picture and showed my husband and I had it correctly. I broke a couple blades, so I scraped that project. OCtoolguy 1 Quote
flarud Posted October 13, 2019 Report Posted October 13, 2019 2 hours ago, kmmcrafts said: Make sure the blade isn't upside down too.. Don't ask how I know that one.. +1 on that. OCtoolguy 1 Quote
Scrappile Posted October 13, 2019 Report Posted October 13, 2019 Just, maybe, wrong blade for that application... Keep at it and don't hesitate to try different blades. It will all come together and you will get your favorites... Tammi201 and OCtoolguy 1 1 Quote
trackman Posted October 13, 2019 Report Posted October 13, 2019 I would use a #5 mg pegas blade. OCtoolguy 1 Quote
Rockytime Posted October 13, 2019 Report Posted October 13, 2019 The great thing is you're trying. Do not get discouraged. Perhaps start with pine which is a lot softer and easier to cut. Getting hooked is real easy and feel free to ask lots of questions. Lot's of people here happy to give you help. tomsteve, OCtoolguy and kmmcrafts 2 1 Quote
LarryEA Posted October 14, 2019 Report Posted October 14, 2019 I would use Olson Skip Tooth Any of these three You can order from Sloanwoodshop.com Part # Width Thickness Teeth Per inch 3/0-ST .022 .008 33 2/0-ST .022 .010 28 2-ST .029 .012 20 OCtoolguy 1 Quote
Tammi201 Posted October 14, 2019 Author Report Posted October 14, 2019 11 hours ago, Scrappile said: Just, maybe, wrong blade for that application... Keep at it and don't hesitate to try different blades. It will all come together and you will get your favorites... 10 hours ago, LarryEA said: I would use Olson Skip Tooth Any of these three You can order from Sloanwoodshop.com Part # Width Thickness Teeth Per inch 3/0-ST .022 .008 33 2/0-ST .022 .010 28 2-ST .029 .012 20 Thank you or all the good help. OCtoolguy 1 Quote
