crupiea Posted October 27, 2019 Report Posted October 27, 2019 Got into ellipses here recently and if you have done these before you will know that there really are no tools to draw the things like there is a compass for circles. Sure, you can draw one of you have an engineering degree and two compasses, a slide rule and some other stuff but man its confusing. I am just relegating myself to using one of those green plastic things, taking a pic of it, emailing it to myself then fiddling with it, There really should just be a $20 tool for this. OCtoolguy 1 Quote
jerry1939 Posted October 27, 2019 Report Posted October 27, 2019 Will this help? (Inkscape). https://www.google.com/search?ei=0ue0XameAcO-tQWexoyIBw&q=inkscape+make+an+ellipse&oq=inkscape+make+an+ellipse&gs_l=psy-ab.3..0i30.90867.98753..102318...0.2..0.118.1510.12j4......0....1..gws-wiz.......0i71j0i7i30j0i5i30j0.RxW0clIS0hE&ved=0ahUKEwipz7GymrvlAhVDX60KHR4jA3EQ4dUDCAo&uact=5#kpvalbx=_Oei0XY20KZKesQXM3rEQ27 jerry crupiea and Dave Monk 2 Quote
jollyred Posted October 27, 2019 Report Posted October 27, 2019 there is a technique for drawing an ellipse, using two nails and a piece of string. Look on Youtube for videos on how to do it. OCtoolguy, JimErn, crupiea and 3 others 5 1 Quote
munzieb Posted October 27, 2019 Report Posted October 27, 2019 (edited) I made a "do Nothing machine" or trammel of Archimedes about a year ago for a project that needed an ellipse. There are several plans on the web. The narrow width is about 4". I made the groves with a router but there several ways to hold the sliding blocks in place. I hold it down with 2 sided tape and a rubber grommet to hold the pencil. If you decide to make one and you need a smaller ellipse, draw out the smallest one you can on card stock and then use a compass and then trace out a smaller dimension and cut out with a scissor and use as a template. Edited October 27, 2019 by munzieb crupiea, Wilson142, OCtoolguy and 1 other 3 1 Quote
jerry1939 Posted October 27, 2019 Report Posted October 27, 2019 Try this: http://tavmjong.free.fr/INKSCAPE/MANUAL/html/ix01.html (Don't know why, but you will need to Copy/Paste the link). Scroll to ellipse. jerry OCtoolguy 1 Quote
teachnlearn Posted October 27, 2019 Report Posted October 27, 2019 If it makes you feel better, I will send you two brad nails and a loop of string for 20 dollars. I've got an engineering degree and apply KISS in my designs and projects. RJF OCtoolguy 1 Quote
OCtoolguy Posted October 27, 2019 Report Posted October 27, 2019 31 minutes ago, teachnlearn said: If it makes you feel better, I will send you two brad nails and a loop of string for 20 dollars. I've got an engineering degree and apply KISS in my designs and projects. RJF Is there some formula for deciding the "size" of your ellipse? How do you go about that? Quote
Woodmaster1 Posted October 27, 2019 Report Posted October 27, 2019 (edited) I cheat and use AutoCAD when I substitute at the local Vocational School and use the plotter to print it at 1:1 scale. The string method and the homemade device works great too. When I taught drafting precad we use the major and minor axis to draw them with a compass. Edited October 27, 2019 by Woodmaster1 OCtoolguy 1 Quote
JimErn Posted October 27, 2019 Report Posted October 27, 2019 13 minutes ago, octoolguy said: Is there some formula for deciding the "size" of your ellipse? How do you go about that? here ya go Ray, wrap your head around this one What is the equation for an ellipse? Use the standard form (x−h)2a2+(y−k)2b2=1 ( x − h ) 2 a 2 + ( y − k ) 2 b 2 = 1 . If the x-coordinates of the given vertices and foci are the same, then the major axis is parallel to the y-axis. Use the standard form (x−h)2b2+(y−k)2a2=1 ( x − h ) 2 b 2 + ( y − k ) 2 a 2 = 1 . ROFLMAO Seems easier to me to use the circle widget in inkscape, draw out an ellipse (default drawing) and on the tool bar set the width and height OCtoolguy and Rockytime 2 Quote
OCtoolguy Posted October 27, 2019 Report Posted October 27, 2019 1 minute ago, JimErn said: here ya go Ray, wrap your head around this one What is the equation for an ellipse? Use the standard form (x−h)2a2+(y−k)2b2=1 ( x − h ) 2 a 2 + ( y − k ) 2 b 2 = 1 . If the x-coordinates of the given vertices and foci are the same, then the major axis is parallel to the y-axis. Use the standard form (x−h)2b2+(y−k)2a2=1 ( x − h ) 2 b 2 + ( y − k ) 2 a 2 = 1 . ROFLMAO Seems easier to me to use the circle widget in inkscape, draw out an ellipse (default drawing) and on the tool bar set the width and height Thanks, I'm going to sit here and drink a beer while I digest all those x's and o's. I used to be pretty good in math but that was over 60 years ago. I forgot every bit of algebra that I ever knew. But thanks for all that anyway. Quote
jerry1939 Posted October 28, 2019 Report Posted October 28, 2019 Crupiea - Scroll up and reread the post from "teachnlearn". For 20 bucks he would send you 2 nails & a piece of string. WAIT and he will probably double the offer. You just pay separate S&H. jerry teachnlearn, JimErn and OCtoolguy 3 Quote
teachnlearn Posted October 28, 2019 Report Posted October 28, 2019 https://www.mathopenref.com/ellipse.html Look at the first ellipse picture on the site. The point on the ellipse moves with the mouse. Notice the line a is from one point in the middle line. Just think of one brad nail being point a, the line a is going to be the string from that brad nail to the outside of the circle. The line b is the string from the other brad nail, point b. When you move the outer string point, less say a to the line that goes through the two brad nails, you get the outer point. That going to be the outer end of the ellipse left of brad a. Move the string point to the line that goes through the brads, say b and go to the right side you get the end of the ellipse from brad nail b. Move the point around the ellipse and remember, point a is a brad nail, point b is a brad nail. The line a is the length the string will reach to the ellipse from nail a. The line b is the string that will reach the ellipse from nail b. Play with the picture, that grab some cardboard, two brad nails and different loops of string, As you move the brad nails closer and further from each other your going to see the ellipse flatten and expand. The string loop will always be the same until you make a different size. A whole group of string loops and you can make an ellipse on the living room floor with the right length. RJF OCtoolguy 1 Quote
teachnlearn Posted October 28, 2019 Report Posted October 28, 2019 7 hours ago, jerry1939 said: Crupiea - Scroll up and reread the post from "teachnlearn". For 20 bucks he would send you 2 nails & a piece of string. WAIT and he will probably double the offer. You just pay separate S&H. jerry BUT WAIT THERES MORE!!!! If you send cash before the end of the day, I'll include a putt putt scoring pencil! RJF OCtoolguy 1 Quote
John B Posted October 29, 2019 Report Posted October 29, 2019 On 10/28/2019 at 5:20 AM, teachnlearn said: If it makes you feel better, I will send you two brad nails and a loop of string for 20 dollars. I've got an engineering degree and apply KISS in my designs and projects. RJF This is the way we learnt at tech, when I was doing my apprenticeship. Oval coffee tables and dinning tables where the thing and we marked out the tops like this. Simple and accurate. Quote
