After the post in the topic regarding spray booths, I thought I'd mention my turntable.
All it is is a piece of19mm chip board, about 450mm diameter. I fitted 4 small casters under it, and a 12mm (1/2")  bolt protruding  about 50mm (2" ) from the bottom. The bolt drops into a hole in the centre of a bench. It can easily be removed and replaced as needed.
I found a lazy-susan type turntable in the garden section of Home Depot for under $4. It's plastic and works great. The bearing is not plastic. I've been using it for years. I used to mess with bonsai plants and I could put one on the turntable and prune it from all angles very easily. So, it has seen it's share of outdoor weather and it just keeps on turnin'.
Without a photo it probably did not happen!
