Seyco Drill Any One Use One? Have One?
rustynail
I have the dremel plunge router with a Wen rotary tool.. total cost was around $60 by the time I bought the Wen.. the plunge router, and the small drill chuck for the tool.. and I got all this stuff cheap..
Just my opinion.. and not having any experience with the Seyco drill.. I think I would go with the Seyco drill... UNLESS you already have a rotary tool that'd work in the plunge router.. This is my take on the plunge router set up I have.. The unit is cheap and made of plastic.. there is some side to side play in the plunging action.. that can make you drill holes on several degrees off of a straight 90.. This isn't as much of an issue if you'er  just drilling thin stock.. but drilling several stack cuts or thicker material if you're not careful to "try" to make it s close to 90 degrees as possible you could be drilling through where you don't want to be drilling through on the back side of the project..  For a few dollars more.. I think the seyco would be much more accurate..
I use my Dremel set up daily.. but I drill my holes away from the edge enough in case I'm not drilling a good 90 degrees.. I won't use it at all where I want a precise hole such as drilling on a line where I will be doing some veining.. I use my regular drill press for that.. Now... as i said.. I don't know the seyco drill either.. maybe it's not accurate either.. That is just something to think about with these small plastic drills.. if there is any slop when new.. it'll have quite a lot in a year or so.. and any slop will throw you off of a true 90 degrees..  But I will say.. I love the set up for just doing quick drilling where accuracy isn't a huge deal and I use the drill press where I need to be spot on..
Just my 2 cents
