wombatie Posted November 30, 2019 Report Posted November 30, 2019 My husband, Terry's got an EX 16 and it's started getting a knocking noise. We have looked at everything we can think of any suggestions? Marg OCtoolguy 1 Quote
JimErn Posted November 30, 2019 Report Posted November 30, 2019 Check the snap loc air hose, I had a knocking and the air hose was being hit by the saw arm when it was in motion OCtoolguy and wombatie 1 1 Quote
scrollerpete Posted November 30, 2019 Report Posted November 30, 2019 Check the adjustment on the upper arm, that the distance between the back and the front is the same. tomsteve and OCtoolguy 2 Quote
OCtoolguy Posted November 30, 2019 Report Posted November 30, 2019 Whatever you find, please let us all know. I do recall a similar problem with the Dewalt 788's but it was caused by the internal tension rod hitting the underside of the cover plate. I'm not sure how the mechanism works on the EX's. The saws are very similar but the tension mechanism is different on the later models. It could also be the main drive rod coming loose where it connects to the crankshaft. I'm not sure what you call it. When I had my Dewalt, I found that the main drive link was coming loose. Once I tightened it and put some blue Loc-Tite on it, the noise never came back. Quote
bcdennis Posted December 2, 2019 Report Posted December 2, 2019 I had the Motor Cam break into 2 that caused a bad knocking noise. You would know if that's the problem though because the blade would not move up and down. tomsteve and OCtoolguy 2 Quote
wombatie Posted December 3, 2019 Author Report Posted December 3, 2019 Thanks for your help guys. Have not had a chance to check your suggestions but will do asap. Marg OCtoolguy 1 Quote
wombatie Posted December 4, 2019 Author Report Posted December 4, 2019 Well we had a look at the saw and it wasn't the air hose. But it was (excuse me for not knowing the technical term) the silver metal bit that connects to the arm, the blade goes in the end. Terry pushed it to see if it was loose and when he started the saw the knocking had stopped. Not sure if the problem is fixed permanently but it is for now. Thanks for trying to help. Marg OCtoolguy and John B 1 1 Quote
John B Posted December 4, 2019 Report Posted December 4, 2019 (edited) Marg, do the blade chucks, clamps move up and down, eg closer together and wider apart, or another way, do you have to hold them closed when putting in a blade. If this is the case, in the top arm is a mechanism that moves the top blade chuck up and down, on my Ex21 this is joined in the middle for some amazing reason. Quite a while ago, the nut that joins these came loose and I had a knocking noise. The nut that uses the saw is always loose Edited December 4, 2019 by John B OCtoolguy 1 Quote
OCtoolguy Posted December 4, 2019 Report Posted December 4, 2019 I'm confused as to what the problem is. I'm not familiar with "thingy" so a picture is truly worth a thousand words. Ivan Nikolaev 1 Quote
JimErn Posted December 4, 2019 Report Posted December 4, 2019 3 hours ago, octoolguy said: I'm confused as to what the problem is. I'm not familiar with "thingy" so a picture is truly worth a thousand words. Thingy connects the hoogalator to the whatchamacallit OCtoolguy, Oscar Myer and wombatie 3 Quote
Rockytime Posted December 4, 2019 Report Posted December 4, 2019 Oh that's easy.. It is kneebler armstrong. wombatie, Oscar Myer and OCtoolguy 3 Quote
OCtoolguy Posted December 4, 2019 Report Posted December 4, 2019 Is that anywhere near the Galvin rod? I know on a 50 Ford, they have a tendency to leak oil at times. wombatie and Rockytime 2 Quote
wombatie Posted December 5, 2019 Author Report Posted December 5, 2019 21 hours ago, John B said: Marg, do the blade chucks, clamps move up and down, eg closer together and wider apart, or another way, do you have to hold them closed when putting in a blade. If this is the case, in the top arm is a mechanism that moves the top blade chuck up and down, on my Ex21 this is joined in the middle for some amazing reason. Quite a while ago, the nut that joins these came loose and I had a knocking noise. The nut that uses the saw is always loose No John the blades go in and out the way they should. Marg OCtoolguy and John B 1 1 Quote
