trackman Posted December 10, 2019 Report Posted December 10, 2019 Do any of you treat cedar before putting on a finish? An if so how/what? It seems like the wood covers different in spots. OCtoolguy and tomsteve 2 Quote
oldhudson Posted December 11, 2019 Report Posted December 11, 2019 If I'm staining wood. I sand it as needed and then, nearly always, seal it with a couple of light coat of shellac. It dries in under an hour. Then give the shellac a light sanding. I've been tempted to try Minwax Sanding Sealer or the Conditioner but haven't been able to get my wallet open. Jim Finn and OCtoolguy 2 Quote
Dave Monk Posted December 11, 2019 Report Posted December 11, 2019 3 hours ago, trackman said: Do any of you treat cedar before putting on a finish? An if so how/what? It seems like the wood covers different in spots. I spray (not rattle can) three coats of pre catalyzed lacquer. First coat really gets sucked up. Soft maple is about the same. Works good for me. OCtoolguy and tomsteve 2 Quote
JimErn Posted December 11, 2019 Report Posted December 11, 2019 Ever since Kevin posted on how to make his beeswax/mineral oil concoction, I have been using that on all wood species, then top coating with lacquer. OCtoolguy and tomsteve 2 Quote
tomsteve Posted December 11, 2019 Report Posted December 11, 2019 if im using cedar- or other woods that blotch- and its going to be stained, i spray it with mineral spirits first. allow the MS to soak in then apply the stain. on cedar, if im just applying a clear topcoat, many times i will apply a 50/50 mixture of BLO/MS. allow that to dry then apply the clear. that helps the clear not soak in so and less coats for good coverage OCtoolguy and NC Scroller 2 Quote
trackman Posted December 11, 2019 Author Report Posted December 11, 2019 4 hours ago, tomsteve said: on cedar, if im just applying a clear topcoat, many times i will apply a 50/50 mixture of BLO/MS. allow that to dry then apply the clear. that helps the clear not soak in so and less coats for good coverage Thanks I will give that a try next time. OCtoolguy 1 Quote
Phantom Scroller Posted December 11, 2019 Report Posted December 11, 2019 Beeswax and mineral oil for me brings out the grain and colours. Roly OCtoolguy 1 Quote
Jim Finn Posted December 13, 2019 Report Posted December 13, 2019 On 12/10/2019 at 7:42 PM, oldhudson said: "... nearly always, seal it with a couple of light coat of shellac. It dries in under an hour. Then give the shellac a light sanding. …" This is what I do with cedar, also. I then spray with lacquer. (rattle can) I use a LOT of cedar. Quote
oldhudson Posted December 13, 2019 Report Posted December 13, 2019 42 minutes ago, Jim Finn said: This is what I do with cedar, also. I then spray with lacquer. (rattle can) I use a LOT of cedar. Just curious, do you mix your own or do use Zinnser or..... Quote
Jim Finn Posted December 13, 2019 Report Posted December 13, 2019 I just brush on Deft and sand it. (usually one, or sometimes, two coats) I spray on rattle can of cheap lacquer. Less than $4 a can. "Krylon Triple thick finish." Gloss. Quote
