Popular Post Blaughn Posted December 11, 2019 Popular Post Report Posted December 11, 2019 This is the final pattern for my Micah 6:8 plaque. I poster several earlier versions some time ago. After I finished the scrolling I debated endlessly (procrastinated) about the finish. With so much time invested I really wished I had a tried and true finish method. I finally decided to use Danish Oil and Lacquer. I read that this works well provided you allow the Danish Oil to dry for at least 4 days. I waited a week and applied 8 coats of spray lacquer. The Lacquer was wet sanded with 320 grade wet-or-dry to knock down any high spots and eliminate dust nibs. I followed this with 600 grade wet or dry. I finished with an extremely light wet sand with 2000 grade wet or dry and a light buff with grocery bag paper. I chose not to glue the plaque on the backer board until it was complete. This allowed me to rinse the sanding slurry out of the lettering. The areas on the back of the Cherry that were to be glued to the backer board were masked off before I applied Danish oil. These areas were matched with the same masking pattern on the backer board before spaying the letter portions of the backer board with flat black lacquer I wiped the plaque dry and blew any remaining water from the letters with compressed air and let it dry overnight before gluing it to the backer board. I also put 2 "insurance" screws through the backer board and into the Cherry (just in case). I did not need to use any wax on the face of the plaque. I think I have found my tried and true finish! It is now ready to be wrapped and gifted to a dear friend. frankorona, amazingkevin, New Guy and 19 others 20 2 Quote
spirithorse Posted December 11, 2019 Report Posted December 11, 2019 Beautiful! A true work of art done with love. Thanks for sharing and God Bless! Spirithorse Blaughn 1 Quote
Scrappile Posted December 11, 2019 Report Posted December 11, 2019 Very beautiful. I would say you found your go to finish... Blaughn 1 Quote
trackman Posted December 12, 2019 Report Posted December 12, 2019 That is an outstanding project!!! Blaughn 1 Quote
JTTHECLOCKMAN Posted December 12, 2019 Report Posted December 12, 2019 Very nicely done. I will caution you though with your choice of finish. You try not to mix poly with lacquers. Not good adhesion. Lacquer will lay on top of poly but with BLO it will blend and lock into wood fibers. Danish oil is BLO,MS,and Poly blended together. You would get the same results if you used BLO. Do not use plain linseed oil. BLO will give the wood a yellow tint as does Danish oil but without the poly. Now you get away with this because you do not use more than one coat of Danish oil and the amount of poly is minimal. Love the project and love the finish. When I use lacquers I polish out using Micromesh 1200 and lemon oil. I like Formbys lemon oil. One other thought those that use wax as a finish do not top coat with either poly or lacquers you are wasting your time. No adhesion at all it will peel. Just some of my thoughts. Do as you may. amazingkevin, Blaughn and John B 3 Quote
John B Posted December 12, 2019 Report Posted December 12, 2019 Excellent piece and very well finished. Next time, just for the sake of argument, try dry sanding, it will work just as well, If you have any dust in the final coat use an oil or wax with very fine paper or steel wool. The amount of effort you put into it definitely shows. Blaughn 1 Quote
amazingkevin Posted December 12, 2019 Report Posted December 12, 2019 I can only dream if doing lettering like this!!! Now I have something to look up too!!! Very special project gone the extra mile and then some. I,d give my first born for this one!!! Makes me bite my teeth!!! Blaughn 1 Quote
Ron Johnson Posted December 12, 2019 Report Posted December 12, 2019 Awesome piece of work Bruce. A gift that will shirly be treasured. Blaughn 1 Quote
Gonzo Posted December 12, 2019 Report Posted December 12, 2019 Wow! That is really beautiful! Blaughn 1 Quote
OzarkSawdust Posted December 12, 2019 Report Posted December 12, 2019 Very beautiful work! The finish turned out fantastic! Blaughn 1 Quote
Phantom Scroller Posted December 12, 2019 Report Posted December 12, 2019 Beautiful wood, great cut. Roly Blaughn 1 Quote
wombatie Posted December 13, 2019 Report Posted December 13, 2019 Beautiful and an amazing finish. Love the wood too. Marg Blaughn 1 Quote
Blaughn Posted December 13, 2019 Author Report Posted December 13, 2019 12 hours ago, wombatie said: Beautiful and an amazing finish. Love the wood too. Marg Thanks Marg. Last year I stumbled across a 7" wide, 8' long, 8-quarter piece of cherry at Woodcraft that was very close to a true quarter sawn stock. With some very careful re-sawing (read fear and trembling) and sectioning to eliminate pitch pockets it has produced some spectacular.40 thick panels perfect for scrolling. Quote
Woodrush Posted December 14, 2019 Report Posted December 14, 2019 You knocked that one out of the park Blaughn 1 Quote
courtym74 Posted December 14, 2019 Report Posted December 14, 2019 Very Beautiful piece!! Thanks for sharing! Blaughn 1 Quote
