Dave Monk Posted December 13, 2019 Report Posted December 13, 2019 I am thinking of purchasing one of these. Does anyone have one of these motors. What do you think? Wondering if it is an issue that it is not variable speed. Currently I am using my drill press for my sanding mops which I realize the bearing aren't made for that. OCtoolguy 1 Quote
Bpardue Posted December 13, 2019 Report Posted December 13, 2019 The motor tends to get real hot during extended use. I think it is a waste of money. I just a variable speed bench grinder that I converted to a flexible drum sander by using the conversion kits from Judy Gale Robert's website. I use a Fordum power carver as well. OCtoolguy, GrampaJim and John B 2 1 Quote
Sycamore67 Posted December 13, 2019 Report Posted December 13, 2019 The Guinevere motor is nice but the other options such as a flex shaft are not cheap. I think it would work fine for you. Foredom also makes a variable speed unit that is only 1/6 hp. I use my variable speed drill press for somethings and do not worry about the bearings on it. If I have a lot to do, I use my Shopsmith and can use both ends of the motor. It is also variable speed. The Guinevere is 3600 rpm and I do not run my sanding mops that fast. Typically, I run them about 1000 rpm which gives me better control. The variable speed is a great feature. There are variable speed bench grinders but seem to only go down to 2000 rpm but are Dave Monk and OCtoolguy 1 1 Quote
Scrappile Posted December 13, 2019 Report Posted December 13, 2019 Seyco sells one too. Might be worth check it out also. I have always wanted one of those... but, little room and little money..... I did order a router lift for my router table.... Merry Christmas to me.... Dave Monk, Woodrush and OCtoolguy 2 1 Quote
Denny Knappen Posted December 13, 2019 Report Posted December 13, 2019 I have the Seyco and have had it for maybe 8 years with no problems. I like that is on a stand. OCtoolguy and Dave Monk 1 1 Quote
meflick Posted December 14, 2019 Report Posted December 14, 2019 (edited) Dave, when I was first wanting to start with Intarsia I went ahead and purchased this one from Guinevere. It spins way too fast and cannot be slowed down since it does not have variable speed. After taking some of JGR’s classes, and using the Foredom in her studio, I purchased one of these with the adaptors and things needed from her shop: https://intarsia.com/collections/hardware/products/foredom-variable-speed-bench-lathe I prefer it to the Guinevere system since it is variable speed. She and I use it when sanding vary small pieces. For sanding larger pieces, she uses a Sand-rite pneumatic drum sander. However, given their price, she has her student stations set up with the flexible drum sanders that she sells on her site. I bought a variable speed grinder at HD or Lowe’s and add the flex drum sanders with the adapters from Judy’s site https://intarsia.com/collections/hardware/Sander and which are the same as Ray sells at Seyco. So if interested, you could get faster delivery given your location from Seyco. they do not sell the Foredom setup though it doesn’t look like. I have that system set up in the shop with the sander on one side and one of Judy’s wonder wheels on the other. I really covet the Sand-rite pneumatic sanders she has but just have not been willing to pull the trigger on that yet. I Haven’t figured out how to sneak it into the shop or explain the “need” for it yet to DH. I can’t remember what sizes she has on it, I think one is 8 or 9” and the other side is like 5 or 6” I think. She lets students use it while in class. It sands faster I think then the flex drum sanders (takes more off). Plus, the flex drum sanders eventually give out since their core is a hard foam and need to be replaced. They are both also on variable speed grinders. You could put the sanding mop on one side easily enough.Having the variable speed is very Important in my opinion. You can see the Sand-Rite system here: https://www.sand-rite.com/store/DUO-DLX-All-Purpose-Contour-Finishing-Sander-c35962737 anyway, my 2 cents. Edited December 14, 2019 by meflick GrampaJim, John B, Dave Monk and 1 other 3 1 Quote
Dave Monk Posted December 14, 2019 Author Report Posted December 14, 2019 38 minutes ago, meflick said: Dave, when I was first wanting to start with Intarsia I went ahead and purchased this one from Guinevere. It spins way too fast and cannot be slowed down since it does not have variable speed. After taking some of JGR’s classes, and using the Foredom in her studio, I purchased one of these with the adaptors and things needed from her shop: https://intarsia.com/collections/hardware/products/foredom-variable-speed-bench-lathe I prefer it to the Guinevere system since it is variable speed. She and I use it when sanding vary small pieces. For sanding larger pieces, she uses a Sand-rite pneumatic drum sander. However, given their price, she has her student stations set up with the flexible drum sanders that she sells on her site. https://intarsia.com/collections/hardware/Sander and which are the same as Ray sells at Seyco. I have that system set up in the shop with the sander on one side and one of Judy’s wonder wheels on the other. I really covet the Sand-rite pneumatic sanders she has but just have not been willing to pull the trigger on that yet. I can’t remember what sizes she has on it, I think one is 8 or 9” and the other side is like 5 or 6” I think. She lets students use it while in class. It sanders faster I think then the flex drum sanders (takes more off). They are both also on variable speed grinders. Having the variable speed is very Important in my opinion. You can see the Sand-Rite system here: https://www.sand-rite.com/store/DUO-DLX-All-Purpose-Contour-Finishing-Sander-c35962737 Do you think it has enough power to use a sanding mop on it? OCtoolguy 1 Quote
meflick Posted December 14, 2019 Report Posted December 14, 2019 2 minutes ago, Dave Monk said: Do you think it has enough power to use a sanding mop on it? Which one Dave, the Foredom or the flex drum sander on the variable speed grinder? For sure the larger one would. I would think the Foredom would as well but cannot say for sure as I have never used one on it. I have not used a sanding mop before really even though I got one a while back. You could call Judy’s shop and ask them. They are very good to help and answer questions on anything. Dave Monk and OCtoolguy 1 1 Quote
John B Posted December 14, 2019 Report Posted December 14, 2019 Just my 2 bob's worth, but wouldn't a grinder do the same thing. I have a small grinder set up with a couple of small sanding drums and it works fine. It's an under powered piece of Chinese ... but it does the job. A standard bench grinder should handle sanding mops no worries. I also have my old drill press set up to use various drums and mops, so a cheap 2nd drill press may be another viable option OCtoolguy and Dave Monk 1 1 Quote
JimErn Posted December 14, 2019 Report Posted December 14, 2019 I'm kind of a make do, kludge it together kind of guy. I took a corded 1/4 drill, chucked a mop in it, and strapped it down with the mop hanging off the work bench. Works fine, it is the grip of the mop that does the work. Dave Monk, OCtoolguy and John B 2 1 Quote
tgiro Posted December 14, 2019 Report Posted December 14, 2019 (edited) 7 hours ago, Dave Monk said: Do you think it has enough power to use a sanding mop on it? The biggest con of the Guinevere is the speed. You can get used to it, but it takes practice - specially when sanding small pieces. The Guinevere chucks are limited in size - I think the largest is 3/8". The Foredom Bench Lathe, that Melanie is refering to, has a chuck limitation of 1/4". Right now, Woodcraft has the Rikon slow speed 8-inch grinder on sale. That is what I'm using. I have a Flex-drum sander on one shaft and a chuck on the other shaft for sanding mops and smaller drums. I got my chuck here - https://www.shopsmith.com/ownersite/catalog/dr_chuck.htm Although, you can, also, find them at McMaster Carr or Grainger. It handles my large mops quite nicely and it works at a speed that is easy to use. I make my own mops and use the 1/2" arbors from Kingspor to mount them. Edited December 14, 2019 by tgiro OCtoolguy, GrampaJim, Dave Monk and 1 other 3 1 Quote
Matt B Posted December 14, 2019 Report Posted December 14, 2019 After taking a class at Judy Gale Roberts, I purchased the Grizzly G8749. It comes with two pneumatic drum sanders and a flap sander. I have owned this for about 15 years and have not had any issues. NC Scroller, Dave Monk and OCtoolguy 2 1 Quote
scrollerpete Posted December 14, 2019 Report Posted December 14, 2019 I used a furnace motor and just install a drill chuck on it, cheap and it works great. Dave Monk, John B, teachnlearn and 1 other 2 2 Quote
orangeman Posted December 14, 2019 Report Posted December 14, 2019 8 hours ago, tgiro said: The biggest con of the Guinevere is the speed. You can get used to it, but it takes practice - specially when sanding small pieces. The Guinevere chucks are limited in size - I think the largest is 3/8". The Foredom Bench Lathe, that Melanie is refering to, has a chuck limitation of 1/4". Right now, Woodcraft has the Rikon slow speed 8-inch grinder on sale. That is what I'm using. I have a Flex-drum sander on one shaft and a chuck on the other shaft for sanding mops and smaller drums. I got my chuck here - https://www.shopsmith.com/ownersite/catalog/dr_chuck.htm Although, you can, also, find them at McMaster Carr or Grainger. It handles my large mops quite nicely and it works at a speed that is easy to use. I make my own mops and use the 1/2" arbors from Kingspor to mount them. I looked at the Guinevere and it is too fast. Will burn cherry! I used to use a variable speed lathe with drill chuck but now use a Rikon low speed grinder with drill chuck so I can use the 3M sanding disks. bb Dave Monk 1 Quote
teachnlearn Posted December 14, 2019 Report Posted December 14, 2019 https://www.amazon.com/Rockler-TATS-26-Router-Speed-Control/dp/B001DT4T4A/ref=sr_1_1?keywords=120+volt+variable+motor+speed+controller+20+amp&qid=1576350309&refinements=p_72%3A2661618011&rnid=2661617011&sr=8-1 One of these kicking around the shop and a tach meter will pretty much control speed of most hand powered/ small shop motors. Searched and found this which is about 20 amps at 120 volts. Hand held tach meter will take care of dialing in the speed you want on a rotating shop tool. RJF Dave Monk 1 Quote
teachnlearn Posted December 14, 2019 Report Posted December 14, 2019 4 hours ago, scrollerpete said: I used a furnace motor and just install a drill chuck on it, cheap and it works great. I like that idea, but I think I would have a problem taking the motor out of the furnace and putting it back every time I needed it. RJF John B, Gonzo, scrollerpete and 1 other 4 Quote
Dave Monk Posted December 15, 2019 Author Report Posted December 15, 2019 7 hours ago, orangeman said: I looked at the Guinevere and it is too fast. Will burn cherry! I used to use a variable speed lathe with drill chuck but now use a Rikon low speed grinder with drill chuck so I can use the 3M sanding disks. bb Brian, Why did you go from the variable speed lathe to the Rikon? Quote
Gonzo Posted December 15, 2019 Report Posted December 15, 2019 7 hours ago, teachnlearn said: I like that idea, but I think I would have a problem taking the motor out of the furnace and putting it back every time I needed it. RJF Now that's funny! Thanks for the laugh Quote
teachnlearn Posted December 15, 2019 Report Posted December 15, 2019 14 hours ago, Gonzo said: Now that's funny! Thanks for the laugh Anytime. Humor is a special part of life. I've thrown lines at my wife for so many years, she can cut me off and finish what I was going to say. RJF John B 1 Quote
dgman Posted December 15, 2019 Report Posted December 15, 2019 2 hours ago, teachnlearn said: Anytime. Humor is a special part of life. I've thrown lines at my wife for so many years, she can cut me off and finish what I was going to say. RJF Maybe it’s time for some new lines! Quote
teachnlearn Posted December 15, 2019 Report Posted December 15, 2019 26 minutes ago, dgman said: Maybe it’s time for some new lines! I've never been a remember a joke guy, so I would put in a line from the situation. The woman can read me. RJF John B 1 Quote
