I also dip puzzles in Danish Oil.  I let them dry thoroughly and a light sanding.  Sometimes, I spray too and bottom with lacquer.  I also have used a finishing wax followed by a buffing wheel.
Since I only make a few for Grandkids and friends, I can take extra time.  If I was making them to sell, I would find a faster method.
I use straight Danish Oil.  I use Ziplock freezer bags and put the pieces in it and then pour the Danish Oil in.  I let them sit for 5 minutes and move things around to get them totally coated.  I pull them out,  wipe and put on a drying rack.  I usually let them dry 24 hours or more.  If I am going to put another coat of finish on, I will wait a bit longer.  I am not in a hurry and do not want to have a problem with pieces not drying completely.
I also dip in Danish oil... I use a dollar store plastic container.. much like a tupperware container.. Let them soak for about 10 minutes.. pull them out and put on a drying table wait another 10 minutes and then wipe and blow out the veining.. I leave them on the dry table for about a week before I seal them up in the shrink wrap bags..
Oh.. I also pour out the Danish oil when done back into the can and wipe out the plastic container with paper towels.. Then I go start a camp fire in the fire pit with the towels and burn my scraps if I have any.. If not.. I still set fire to the rags.. The oil soaked rags can con-bust on it's own so be careful with them.. I've read that people will put them in a bucket of water.. I just set them on fire so i expect it to burn while I'm "watching" it rather than leave them and forget to keep and eye on them..
52 minutes ago, jpedersm said:
I guess I have been using watch natural danish oil to stain my other projects with foam brushes.  Will they combust as well and could I just leave the danish oil in a plastic container for dipping?
I think it's best to store the Danish oil in the original can that it's purchased in... The chemicals in it may soften the plastic of the container.. I only use the container for dipping and then wipe it out with paper towels.. then burn the towels.. I live out in the country so I have no issues with burning a couple paper towels every now and then.. I don't do finishing every day.. and try to have a large batch of stuff to to at once..
