Matt B Posted December 23, 2019 Report Posted December 23, 2019 I have been cutting patterns by Sam Custodio and have been using maple since it is a strong wood with closed pores. My process to prepare wood is to purchase 1" wood, resaw it in half and plane to thickness. I really like Walnut, but it does have open pores. Is it strong enough for scrolling when about 1/4 to 3/8" thick? I know I can try it myself but I will ask for opinions anyway. Thanks, Matt OCtoolguy 1 Quote
Denny Knappen Posted December 23, 2019 Report Posted December 23, 2019 Hi Matt. I used 1/4" Walnut, but not for fretwork. I did a 1/2" Walnut trivet and it cut without any problems. OCtoolguy 1 Quote
JimErn Posted December 23, 2019 Report Posted December 23, 2019 I've used 3/8th walnut both as the major piece and as inlay, it cuts and finishes well OCtoolguy 1 Quote
dgman Posted December 23, 2019 Report Posted December 23, 2019 (edited) Matt, just because a wood has open pores does not make it weaker. Woods with open grains may be weaker, but not necessarily open pores. I use Walnut all the time for fretwork. I even use it for ornaments usually in 3/16” without any problems. As with any hardwood, you want to orient the pattern for the best possible grain strength, but it should be fine to cut. Edited December 23, 2019 by dgman OCtoolguy 1 Quote
Jim McDonald Posted December 23, 2019 Report Posted December 23, 2019 I've done 1/4" walnut for ornaments--but they don't get handled much so the wear and tear is not a problem. OCtoolguy 1 Quote
bcdennis Posted December 23, 2019 Report Posted December 23, 2019 I work with 1/4 Walnut for ornaments and such and it works great. No problems at all. OCtoolguy 1 Quote
Bill WIlson Posted December 23, 2019 Report Posted December 23, 2019 I've used 1/4" walnut, red oak and other open grained woods for fretwork. They hold up fine. I've gone down to 3/16" thick with no real problems. I've done thinner, but you have to be selective in the pattern if you use 1/8" hardwood. If I want something that thin, I typically go to BB ply. Like any other wood, narrow cross grain sections will be fragile, but I don't think walnut is inherently weaker than maple. OCtoolguy 1 Quote
Matt B Posted December 23, 2019 Author Report Posted December 23, 2019 Great. Thanks everyone for sharing your experience. Matt OCtoolguy 1 Quote
JTTHECLOCKMAN Posted December 23, 2019 Report Posted December 23, 2019 I agree with others. Walnut is fine for scrolling fret work so is red oak which I use alot of and is more open grain than all of them. Mahagony is good as well. OCtoolguy 1 Quote
Gonzo Posted December 24, 2019 Report Posted December 24, 2019 I will agree with the others. I use 1/4" maple with 1/4" walnut quite a bit. No problems at all. Which is really cool, because we all know how beautiful of a contrast they are when used together. JTTHECLOCKMAN and OCtoolguy 1 1 Quote
