Excalibur blade ensionning
Mr sawdust
The first thing is to make sure the arm is absolutely parallel to the table from front to back. Once that setting is done, you won't need to turn the big black knob at all. Unless you just feel that you need more tension. As was mentioned, the white plastic lever may be worn out too. Follow the instructions in the manual. If you didn't get the manual with the saw, you can download it online. Once you get used to that saw, unless the previous owner wore it out, you will love it. My main suggestion is to spend another $100 on the Pegas clamp set. It might just prove to be the answer to all your problems. But start with leveling the arm first.
30 minutes ago, Mr sawdust said:
Seems bottom blade was slipping the blade,   Tighned it some , seems to work...
You may need to rough up the ends of the thumb and set screw or at least give them a good cleaning. Sometimes they get a oil residual from the blades. All blades have a fine coating of oil on them to prevent rust. This can build up on the clamping surface of the screws.
I've been having to really clean my blades lately and even rubbing them on some 400 sandpaper. It seems to be something common to the Pegas clamps/blades. It just started happening so I have to blame it on that oil you mentioned.
Yeah, after sanding some and getting them crooked some years ago I did the sanding jig thing.. It's the only way to do it.. Just be careful to also start threading it into the wood straight.. as the wood is soft and you make the threads by turning it in straight.. The ideal thing to do is to make a metal  plate with threads.. but this works fine as long as you're careful to get it started straight.. I think I originally seen this tip on Steve Goods blog..
I rarely have to dress the screws and most probably wouldn't have to do it.. Since I work on cars a lot I always keep cans of brake clean around.. I typically remove the screws and spray paper towel, wipe them down good then add a drop of 3-N-1 oil to the threads so they thread smooth into the clamps.. Make sure you don't get the oil on the tips, LOL.. Dirty threads will make you think you're clamping down hard on the blade.. but you threads are actually binding with grime in them.. I keep them running good and smooth.. Run my DeWalt for 10+ years production cutting with the original clamps and screws only dress them about 3 times..  Also.. I never have cleaned off the blades themselves or sanded them etc.. I just clean up the screws about every couple weeks..
Caution doing the brake clean though.. it will melt the little O-ring on the screws tips if you have the rotating tips like the EX and Dewalt saws have.. also hard on the plastic portion of the handle.. I always spray on a paper towel and then wipe the tips down and then the threads after it started to dry up.. rather than spraying the actual thumb screw and soaking the whole thing..   Has worked well for me doing this.. hardly ever dress out the screws like I used to do..
On 12/30/2019 at 5:07 PM, Mr sawdust said:
Hi to ya all..
i just bought a used ExcaliburEX-21, i,m having a hard time with blade tension,  It just won t tight up..can anypne help?
Sorry I should have read the rest of the posts.
At some point I would upgrade the clamp assembly with the Pegas version.
 If you don't have the manual for the saw I would suggest downloading it and follow their guide lines.
http://www.general.ca/pdf/machines/excalibur/EX-16_21_30_ENG.pdf
DGMAN, I would take that jig a bit further and take a piece of flat metal, drill and tap it on the drill press.
Edited by Rolf
Or you can get a nut of the same thread pitch and epoxy it to a flat board, drill a hole through the board and have a good jig.
Yes, that would be good but most of us are not metal workers. I don’t have a piece of flat steel laying around. I will stick with a wood block. It’s lasted years now so I don’t see a need for metal.
