new2woodwrk Posted January 11, 2020 Report Posted January 11, 2020 Just wondering if anyone uses permanent patterns? I've been reading about them today and thought it would be a good idea for some cuts - mostly silhouettes or limited fretwork I think? Thoughts? Thanks for reading. OCtoolguy 1 Quote
JimErn Posted January 11, 2020 Report Posted January 11, 2020 Never heard of them or the use, but at first blush, If it was permanent the only way I can see to use them is to put them on the reverse side of the piece OCtoolguy and new2woodwrk 2 Quote
new2woodwrk Posted January 11, 2020 Author Report Posted January 11, 2020 57 minutes ago, JimErn said: Never heard of them or the use, but at first blush, If it was permanent the only way I can see to use them is to put them on the reverse side of the piece Here's part of the article I've been reading: OCtoolguy 1 Quote
ike Posted January 11, 2020 Report Posted January 11, 2020 I have about 500 patterns to make a perminate pattern of each would take the rest of my life, I am 80 It is so easy to take a copy and spray glue it on wood and then remove it with meneral sperits. I do have one permanate pattern and it is of a oven pull which I give away to women when they buy somethinf at the craft shows. IKE OCtoolguy, new2woodwrk, tomsteve and 1 other 4 Quote
Badgerboy Posted January 11, 2020 Report Posted January 11, 2020 My 88 year old Uncle-in-law, who inspired me to start scrolling, always makes a permanent pattern. I believe part of the reason is the computer and printer perplex him at times but mostly it is out of habit. He also taught me to use a “story stick” for my cabinet making projects. He is a master carpenter and at 88 a bit set in his ways which is good with me. I am using paper patterns except for one project set that I have been asked to make many copies and therefore a traceable hard pattern makes sense. I use 1/8 inch stock for these patterns. new2woodwrk and OCtoolguy 1 1 Quote
kmmcrafts Posted January 12, 2020 Report Posted January 12, 2020 I'll stick to computer files to print on paper.. with ability to modify, resize, personalize etc etc etc... Not very practical for what i do.... I could see this for certain type of projects..but not for the things I make.. tomsteve, new2woodwrk and BadBob 3 Quote
fredfret Posted January 12, 2020 Report Posted January 12, 2020 I use templates for making toy cars that I donate. I cut them from scraps so having a pattern to trace around is easier than printing one. I often cut 30 plus in a day new2woodwrk 1 Quote
dgman Posted January 12, 2020 Report Posted January 12, 2020 I would have to have boxes and boxes full of templates if I did it that way. Not to mention the time it would take to make a template before cutting the project. tomsteve and new2woodwrk 2 Quote
kmmcrafts Posted January 12, 2020 Report Posted January 12, 2020 23 minutes ago, dgman said: I would have to have boxes and boxes full of templates if I did it that way. Not to mention the time it would take to make a template before cutting the project. Depending on how thick of wood you cut but a template could be added ( stack cut ) so after the first cut you have your template for the next time you cut.. new2woodwrk 1 Quote
loftyhermes Posted January 12, 2020 Report Posted January 12, 2020 I have a few permanent patterns mostly made out of modern furniture drawer bottoms and cupboard backs. It's mostly 1/8" mdf or ply. I glue the paper pattern to it then fix it to the wood, generally with pins and cut it then I have my template ready for next time. new2woodwrk 1 Quote
lawson56 Posted January 12, 2020 Report Posted January 12, 2020 I guess you can say I am close to a Permanent Pattern maker,I use Carbon paper,so my patterns do last quit some time. tomsteve and new2woodwrk 2 Quote
NC Scroller Posted January 12, 2020 Report Posted January 12, 2020 I currently have and use a couple templates. They can be handy if you are making multiples of the same thing and they can't be stack cut. By multiple I am not talking 1 or 2. new2woodwrk 1 Quote
nrscroller Posted January 12, 2020 Report Posted January 12, 2020 Hi, When I get a pattern, I make a copy and save as original and file it, then just pull that and print a copy. I file them under different artists or general or various topisc, I am 74 and has worked for years for me Bill tomsteve and new2woodwrk 2 Quote
Bill WIlson Posted January 12, 2020 Report Posted January 12, 2020 I think templates are a viable alternative to re-printed paper patterns....in come limited circumstances. For example, simple silhouettes & shapes can be re-produced faster by tracing around a template, but beyond that, for more detailed work, I think using a paper pattern will give you better, more accurate and consistent results. new2woodwrk and MrsN 2 Quote
MrsN Posted January 13, 2020 Report Posted January 13, 2020 18 hours ago, Bill WIlson said: I think templates are a viable alternative to re-printed paper patterns....in come limited circumstances. For example, simple silhouettes & shapes can be re-produced faster by tracing around a template, but beyond that, for more detailed work, I think using a paper pattern will give you better, more accurate and consistent results. Bill has a good point permanent patterns or templates work well for really simple designs. new2woodwrk and Rolf 2 Quote
Rolf Posted January 13, 2020 Report Posted January 13, 2020 Templates for simple stuff yes, for my detailed work not realistic, too time consuming and the probability of missing a detail too high. new2woodwrk 1 Quote
NC Scroller Posted January 13, 2020 Report Posted January 13, 2020 Here is a case in point. I cut this Sue Mey design. She has a number of overlays (love, joy, peace, faith, hope, Jesus, etc). Since I was doing 24 crosses in total and I was using 3/4" stock for the backer stack cutting was out of the questions. So I put the pattern one time on a piece of 1/8" hardboard, cut it out and used it to trace out all my crosses. The 1/8" template is hanging on my shop wall with other similar templates for future use. new2woodwrk 1 Quote
kmmcrafts Posted January 13, 2020 Report Posted January 13, 2020 Well now that I think about it I do use a template.. My bases for my clocks and other things I made templates for.. Though most are not scroll sawn.. I pretty much cut the bases on the table saw or bandsaw and then use the template to mark the rounded corners.. Typically use the disc sander to get the corners rounded off and then finish smoothing them with the hand sander... and i would do this with silhouette stuff if I was doing a lot of it.. new2woodwrk 1 Quote
jerry1939 Posted January 13, 2020 Report Posted January 13, 2020 IF you want a template, use a thin plexiglass in a stack. Easier to trace around. For making paper copies of a pattern, I always cut off a corner of the original. That way I didn't end up making copies of copies later. jerry Rolf and new2woodwrk 2 Quote
Rolf Posted January 14, 2020 Report Posted January 14, 2020 That is a great suggestion 17 hours ago, jerry1939 said: IF you want a template, use a thin plexiglass in a stack. Easier to trace around. For making paper copies of a pattern, I always cut off a corner of the original. That way I didn't end up making copies of copies later. jerry new2woodwrk 1 Quote
Roberta Moreton Posted January 14, 2020 Report Posted January 14, 2020 To me a permanent pattern or template refers to a silhouette. new2woodwrk 1 Quote
BadBob Posted January 18, 2020 Report Posted January 18, 2020 On 1/11/2020 at 8:05 PM, kmmcrafts said: I'll stick to computer files to print on paper.. with ability to modify, resize, personalize etc etc etc... Not very practical for what i do.... I could see this for certain type of projects..but not for the things I make.. The first thing I do with a new project is what ever it takes to get it into SVG format in the computer. Using Inkscape I can print patterns any size I want with sharp clear lines. new2woodwrk 1 Quote
