What does one use to color wood puzzles?
I have Acrylic paint, but I'm concerned that painting the pieces would cause them to not fit properly after wards.
I've tried food coloring, but I can't seem to get a good coated color.
Thoughts?
Thanks as always in advance for your help
I have painted both poplar and pine puzzles with acrylic craft paint and not had an issue with the wood swelling to the point the pieces no longer fit.  Yes you will get minimal swelling especially when it is still wet but not enough to ruin the puzzle.  Just make sure you apply thin coat(s) of paint.   I have even thinned the paint with water at times to make it more of a stain than paint.
Edited by NC Scroller
typo
Thoughts?
I use food colors but it has taken me 9 years to perfect the technique!  Not something I can spell out in a couple paragraphs.
I invite you to some see my colored puzzles at the Fairhope, AL Arts and Craft show - March 20-22, 2020.
bb
www.pickenspuzzles.com
bb
Thanks - that's about a 4 hour drive for me😞
i am very curious about Unicorn Spit  -do the colors bleed into one another when dry , does it raise the grain on soft woods
and does it rub off on hands or clothing -looking for a permanent easy to use (and easy to clean )
also are gloves necessary ?  Thanks
Edited by Puzzleguy
There is was a detailed threaded on Unicorn Spit on the other forum last year.  Gloves are a must.
1 hour ago, new2woodwrk said:
Is this the thread?
I think the detailed thread on the “other forum” that Scott referred to is over on the forum for the magazine, “Scroll Saw Woodworking & Crafts”. There are a couple threads over there discussing ”Unicorn Spit.” There was one by @Jim McDonald where he did different experiments with diluting. It is here: https://forum.scrollsawer.com/forum/scroll-saw/wood-finishing-and-painting/864165-unicorn-spit-experiment
in my little use so far of it, which has been limited, I did not notice it really raising the grain but I used it “full strength” without diluting it. Once completely dry, I did not notice it rubbing off at all. It is probably a little more “stain” then “paint”. I did have it “stain” my hands a bit when I didn’t use gloves, but it cleaned off easily with soap and water as best I recall but did try to use gloves when I used it. It was just as easy to use and cleanup as using acrylic paints.
