baggetta Posted January 12, 2020 Report Share Posted January 12, 2020 Here's something a bit different. I've been cutting signs lately with images cut in the letters of a word or phrase, like the Music and Soccer signs below. This one was done similarly for Dancers. Instead of cutting out the figures and leaving an open space, I decided to cut the figures at a 5 degree angle cut on the scroll saw. This allows the figures to pop out and hold instead of dropping out altogether. I cut the DANCE from teak and also the figures, but I took the figures and dipped them in a dark stain, then replaced them in the word. This was all mounted on a rectangle base of cherry and sprayed with a clear sealer. The pattern shows the left degree cut that is necessary and the direction you should cut to get similar results. To be sure, do a sample test cut before committing to the final cut. Pattern available on my Free Pattern Page: http://baggetta.com/pebooks/puzzle_patterns.htm dgman, frankorona, jollyred and 4 others 6 1 Quote Link to comment Share on other sites More sharing options...
daveww1 Posted January 13, 2020 Report Share Posted January 13, 2020 very nice Quote Link to comment Share on other sites More sharing options...
