JimErn Posted January 21, 2020 Report Posted January 21, 2020 great work, I need to ask though, why did you start at the outside? not finding fault, just wondering if there was a reason since I would started in the middle don watson and OCtoolguy 1 1 Quote
spirithorse Posted January 21, 2020 Report Posted January 21, 2020 Looking forward to seeing your finished project, Paul, God Bless! Spirithorse OCtoolguy 1 Quote
Scrappile Posted January 22, 2020 Author Report Posted January 22, 2020 Late start, but some progress today.... Before I started scrolling, I drill all the rest of the holes today. Have to take a lot of care, would be easy drill in the wrong spot, because the cut out parts are not black. Glad to get that done because I was worried I would put holes where they should not be. I am having a great time. Drilling and scrolling I spent about 4.5 hours on it today. don watson, TripleJScroller, Oscar Myer and 3 others 4 2 Quote
dgman Posted January 22, 2020 Report Posted January 22, 2020 Looking great Paul! I noticed you aren’t cutting the traditional cutting from the center out. Any particular reason? Scrappile and OCtoolguy 1 1 Quote
Scrappile Posted January 22, 2020 Author Report Posted January 22, 2020 1 hour ago, dgman said: Looking great Paul! I noticed you aren’t cutting the traditional cutting from the center out. Any particular reason? Nope, just didn't. Partly because I have never scrolled Maple before so I started along one side, and only drilled holes in about a 1" wide strip along one side. Figured if I run into trouble with the maple, I could just cut off the part that I had drilled and cut, and save the rest for some other project. Got started and just kept going around the outside. I like cutting the Maple. Also, I rarely start in the middle, now that I think of it. Maybe it is my wood miser-ness.. OCtoolguy 1 Quote
dgman Posted January 22, 2020 Report Posted January 22, 2020 3 hours ago, Scrappile said: Nope, just didn't. Partly because I have never scrolled Maple before so I started along one side, and only drilled holes in about a 1" wide strip along one side. Figured if I run into trouble with the maple, I could just cut off the part that I had drilled and cut, and save the rest for some other project. Got started and just kept going around the outside. I like cutting the Maple. Also, I rarely start in the middle, now that I think of it. Maybe it is my wood miser-ness.. I understand. I’m sure you are finding that hard Maple is very easy to cut or at least it is for me. I love how the cut edges come out so smooth and even shiny. Although I’ve never stained Maple, it does take a topcoat very nicely. OCtoolguy and Scrappile 1 1 Quote
Scrappile Posted January 22, 2020 Author Report Posted January 22, 2020 On 1/21/2020 at 9:25 AM, JimErn said: great work, I need to ask though, why did you start at the outside? not finding fault, just wondering if there was a reason since I would started in the middle 6 hours ago, Scrappile said: Nope, just didn't. Partly because I have never scrolled Maple before so I started along one side, and only drilled holes in about a 1" wide strip along one side. Figured if I run into trouble with the maple, I could just cut off the part that I had drilled and cut, and save the rest for some other project. Got started and just kept going around the outside. I like cutting the Maple. Also, I rarely start in the middle, now that I think of it. Maybe it is my wood miser-ness.. Sorry @JimErn I missed your question in your post. Please see quote above.... OCtoolguy 1 Quote
cowboyup3371 Posted January 23, 2020 Report Posted January 23, 2020 Can't wait to see the finished product OCtoolguy 1 Quote
Scrappile Posted January 23, 2020 Author Report Posted January 23, 2020 (edited) Well, made it quite a ways this evening. All the way around the outside except for some of the "veining" that I do with the 2/0 size spiral. I just got tired again and you gotta know when to fold.... Know when to..... walk away.... The 4 larger areas not cut on the out side of the circle is because there are nails in them to hold the stacked wood together. They are scrolled last. Edited January 23, 2020 by Scrappile OCtoolguy 1 Quote
JimErn Posted January 23, 2020 Report Posted January 23, 2020 Looks really good, kudo's Be careful with the finger tips when turning the piece while doing the center cuts, some of those look pretty fragile OCtoolguy 1 Quote
spirithorse Posted January 23, 2020 Report Posted January 23, 2020 Your friend is certainly going to love this, Paul! Amazing work! Thanks for sharing and God Bless! Spirithorse I know there is only about 1/16th" difference in the two woods you are using but, are you going to have to change the tabs when you make the final cuts on the outside edges? Just curious and wondered if you had considered that yet. Scrappile and OCtoolguy 1 1 Quote
Scrappile Posted January 23, 2020 Author Report Posted January 23, 2020 1 hour ago, spirithorse said: Your friend is certainly going to love this, Paul! Amazing work! Thanks for sharing and God Bless! Spirithorse I know there is only about 1/16th" difference in the two woods you are using but, are you going to have to change the tabs when you make the final cuts on the outside edges? Just curious and wondered if you had considered that yet. Only on the 1/4" BB. The patterns is sized for 3/16" and that is the thickness of the Maple. OCtoolguy 1 Quote
spirithorse Posted January 24, 2020 Report Posted January 24, 2020 Good deal! Keep up the good work and keep us posted. God Bless! Spirithorse OCtoolguy and Scrappile 1 1 Quote
scrollingforsanity Posted January 24, 2020 Report Posted January 24, 2020 very, very nice Paul. Scrappile and OCtoolguy 1 1 Quote
Oscar Myer Posted January 24, 2020 Report Posted January 24, 2020 Amazing work!!! /Oscar Scrappile and OCtoolguy 2 Quote
Jim McDonald Posted January 25, 2020 Report Posted January 25, 2020 Quite a bit of work, but the finished product will be worth it. OCtoolguy and Scrappile 2 Quote
Denny Knappen Posted January 25, 2020 Report Posted January 25, 2020 Paul, that is an amazing work in progress. OCtoolguy and Scrappile 2 Quote
Popular Post Scrappile Posted January 25, 2020 Author Popular Post Report Posted January 25, 2020 Just finished scrolling the lid to the box. This is with the pattern removed and laying a piece of red felt. Was at it four hours today, have probably have a little over 12 hours in cutting so far. cowboyup3371, Matt B, JimErn and 7 others 9 1 Quote
Dave Monk Posted January 25, 2020 Report Posted January 25, 2020 8 hours ago, Scrappile said: Just finished scrolling the lid to the box. This is with the pattern removed and laying a piece of red felt. Was at it four hours today, have probably have a little over 12 hours in cutting so far. That is looking awesome! Scrappile and OCtoolguy 1 1 Quote
Foxfold Posted January 25, 2020 Report Posted January 25, 2020 Oh Wow, that is absolutely beautiful. !! Scrappile and OCtoolguy 1 1 Quote
Gonzo Posted January 25, 2020 Report Posted January 25, 2020 Wow! That is impressive. OCtoolguy and Scrappile 1 1 Quote
rjweb Posted January 25, 2020 Report Posted January 25, 2020 Beautiful cutting Paul, getting closer to the finished project, RJ Scrappile and OCtoolguy 1 1 Quote
OCtoolguy Posted January 25, 2020 Report Posted January 25, 2020 Paul, what saw are you using? Just curious with all that fine detail. It's truly beautiful. Scrappile 1 Quote
Scrappile Posted January 25, 2020 Author Report Posted January 25, 2020 11 minutes ago, octoolguy said: Paul, what saw are you using? Just curious with all that fine detail. It's truly beautiful. The saw I use most, Hegner. The Seyco would do it, I just am most comfortable with the Hegner, not sure why. OCtoolguy and Oscar Myer 2 Quote
OCtoolguy Posted January 25, 2020 Report Posted January 25, 2020 Just now, Scrappile said: The saw I use most, Hegner. The Seyco would do it, I just am most comfortable with the Hegner, not sure why. I know that I would not feel comfortable trying to do that cut on my Hawk. At least not yet. My comfort zone is on my EX. I was just wondering which of your saws was your most comfortable to you. Scrappile and Oscar Myer 2 Quote
