Popular Post baggetta Posted January 31, 2020 Popular Post Report Posted January 31, 2020 Spring Flower Outline Sign Pattern "Spring Is In the Air"...Ok, not quite yet, but here's a rather springy sign you might like to cut for a table display. It's a fairly easy sign to cut, but the flowers might be a bit tricky, if you are new to scroll sawing. You have to be sure to leave enough wood where the lines intersect, otherwise the flowers become very breakable. I cut mine out of 1/2" birch plywood and made a custom improvised base out of pine for the base. The entire project was sprayed with a clear spray (2 coats) to make it nice and smooth. Before spraying, make sure you round over the edges by giving it a good sanding. Free pattern is available on my Free Pattern Page: http://baggetta.com/pebooks/puzzle_patterns.htm jollyred, meflick, frankorona and 8 others 11 Quote
amazingkevin Posted February 1, 2020 Report Posted February 1, 2020 Just the right touch of creativity every time!!! Quote
rjR Posted February 1, 2020 Report Posted February 1, 2020 I like the thinking--OUT OF THE BOX! Nice Work! As far as I am concerned--patterns are a place to start FROM! Quote
